Programming Language
You can use a "Run VBScript" module to run VBScripts from within VoiceGuide - or you can use the "Run Program" module to run any program written in any language.
lets say that i used the "Run Program"
and run a perl script
"perl.exe myscript.pl Var1 Var2 Var3"
how can i return the result back to voiceguide
and
how can i use the advanced objects like: Script_Goto
Please see VoiceGuide's Help file entry on Run Program module. Online copy of relevant page is here: http://www.voiceguide.com/vghelp/html/modR...dRunProgram.htm
If the 'wait' option is selected then VoiceGuide will pause until the program completes and afterwards VoiceGuide will look for the result file which can be optionally created by the called program.
Also, if you can instantiate COM interfaces from within Perl then you will be able to use all of the VG's COM functions (Script_Goto, Run_ResultReturn, etc) from within Perl as well.
