Fax And Dial Out Issues
I'm having trouble setting up the fax-back. I've tried many variations.
Is it possible to use another fax program other than
WINFAX with version 2.9 ?
DIAL-OUT problem with version 2.9
How can I set the TIME for continuance to the next module to MOVE FASTER once the call is answered using the DIAL OUT module of version 2.9
I.E. NOT the separate DIALER program to a list, but the dial out module which dials out to ONLY ONE number.
I.E. How can I REDUCE the time allowed before it'll continue to the next module AFTER the call is answered ??
I'm not very familiar with the v2.9 (its fairly old software now - it's 16-bit!) but I know that it did not use any "Timeout" paths like v4 does - so you could not change the built in timeouts.
As far as fax goes, v2.9 was only tested with WinFax 4.0 - and I'd assume that it would work with current WinFax 10, but it has not been tested...
Can you use v4 of VoiceGuide instead?
