Pc Shutdown
I am trying to use VG as an answering system. I have set up a simple script that answers the call, and plays a message then hangs up. When I try it, the call is answered, but as soon as it goes to play the announcement, the computer reboots. I am able to use other applications (i.e. FaxTalk). I only have one modem, it is a Motorola SM56 PCI. I have tried it in two computers with the same result. Both computers have AMD CPUs (one is 850MHz one is 1550MHz). I assume the problem is with the modem. Is this correct? Or is there an issue with AMD CPUs? Thank you.
I have tried both windows XP and Windows 2000 (Both Pro). The problem occurse on both identically. As for the problem being with the modem driver - Do you have a recomendation for this? Thank you
I'd try asking the modem manufacturer if they have any newer drivers available, and if they do not then I'd try using a different modem...
