Guest developer Report post Posted 11/07/2004 03:49 AM 074134.31 0 ApiMode=[TAPI] 074134.31 0 Tapi device 0 is: INTEX Motorola SM56 PCI Speakerphone Modem 074134.75 0 init vgmulti ver 5.2.3018 074134.80 0 Inband Signaling Config file not specified 074134.80 0 Loading VMB data begin 074134.86 0 Loading VMB data - about to delete old entries 074134.86 0 Loading VMB data - sorting/ordering 074134.86 0 Loading VMB data end 074135.46 0 init clear settings on 1 devices. 074135.46 0 Initialising... 074135.52 0 init attach vgs on 1 devices. 074135.52 0 Script Load E:\SOFTWARE\VoiceGuide\KuanYinScripts\AmitabhaNew.vgs 074135.90 0 init lineopen on 1 devices. 074135.90 0 Calling .lineOpen on device 1 074136.56 0 lineOpen(0)=> 074136.56 0 Calling .GetLineHandle on LineId 0 074136.56 0 hLine=4328560 074136.56 0 Calling .GetProviderInfo on LineId 0 074136.56 0 tapi ProviderInfo: Windows Telephony Service Provider for Universal Modem Driver 074136.56 0 set provider type: PROVTYPE_MODEM 074136.56 0 Calling lineSetNumRings on lLineHandle 4328560 074136.56 0 Waiting for a call... 074156.61 0 callstate OFFERING 4328960 0 4 074156.61 0 ring 1 074156.61 0 Answer the call at 11/7/04 7:41:56 AM 074156.61 0 lineAnswer(4328960) => 1 074156.61 0 tapi Reply (LineEvReply) ok 1 0 074156.61 0 callstate ACCEPTED 4328960 0 0 074157.82 0 callstate CONNECTED 4328960 0 0 074157.82 0 callstate CONNECTED 4328960,0,0 074157.82 0 WorkingModeTAPI@Connected= 074157.82 0 WorkingModeScript@Connected= 074157.82 0 Inband detection not enabled 074157.82 0 StartLoadedVgs at 11/7/04 7:41:57 AM 074157.82 0 AddRVns [scriptsPath]{E:\SOFTWARE\VoiceGuide\KuanYinScripts\} 074157.82 0 AddRVns [scriptPath]{E:\SOFTWARE\VoiceGuide\KuanYinScripts} 074157.82 0 rv add [$RV_STARTTIME]{11/7/04 7:41:57 AM} 074157.82 0 rv add [$RV_DEVICEID]{0} 074157.82 0 rv add [$RV_CIDNAME]{} 074157.82 0 AddRVns [PathApp]{D:\PROGRAM FILES\VOICEGUIDE\} 074157.87 0 rv add [$RV_CIDNUMBER]{} 074157.87 0 timer clear 074157.87 0 [Welcome] Number Input 074157.87 0 [Welcome] Playing (D:\Program Files\VoiceGuide\AmitabhaSoundFiles\SeekDonateUpdate.wav) 074157.87 0 play set playid=708902 074158.20 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\AmitabhaSoundFiles\SeekDonateUpdate.wav] 074158.20 0 timer clear 074158.20 0 wa(17789,70890200) 074206.66 0 dtmf 1 (4328960,49,2) 074206.66 0 ScriptEventCode 49 iLineState=1300 074206.66 0 LsGetNbrsPlayWelcMsg 1 074207.37 0 PlaySoundStop err=0 074207.37 0 [Welcome] Number Input 1 074207.37 0 rv add [Welcome]{1} 074207.43 0 timer clear 074207.43 0 [seeker] Number Input 074207.43 0 [seeker] Playing (D:\Program Files\VoiceGuide\AmitabhaSoundFiles\bloodgroup.wav) 074207.43 0 play set playid=718456 074207.65 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\AmitabhaSoundFiles\bloodgroup.wav] 074207.65 0 timer clear 074207.65 0 wa(14280,71845600) 074210.01 0 dtmf 4 (4328960,52,2) 074210.01 0 ScriptEventCode 52 iLineState=1300 074210.01 0 LsGetNbrsPlayWelcMsg 4 074210.56 0 PlaySoundStop err=0 074210.56 0 [seeker] Number Input 4 074210.56 0 rv add [seeker]{4} 074210.61 0 timer clear 074210.61 0 [positiveORnegative] Number Input 074210.61 0 [positiveORnegative] Playing (D:\Program Files\VoiceGuide\AmitabhaSoundFiles\positiveornegative.wav) 074210.61 0 play set playid=721655 074210.78 0 PlaySoundStart ok [D:\Program Files\VoiceGuide\AmitabhaSoundFiles\positiveornegative.wav] 074210.83 0 timer clear 074210.83 0 wa(9018,72165500) 074213.41 0 dtmf 1 (4328960,49,2) 074213.41 0 ScriptEventCode 49 iLineState=1300 074213.41 0 LsGetNbrsPlayWelcMsg 1 074213.96 0 PlaySoundStop err=0 074213.96 0 [positiveORnegative] Number Input 1 074213.96 0 rv add [positiveORnegative]{1} 074214.02 0 timer clear 074214.02 0 [searchPhones] DB Query 074214.02 0 db Jet mode used (To use ODBC mode specify ODBC Connect string) 074214.07 0 rv replace start: [sELECT Phone FROM nameNphone WHERE [Group= $Rv[seeker] AND PositiveORnegative= $Rv[positiveORnegative]]] 074214.13 0 rv ns [PathSysVoice]{}[PathApp]{D:\PROGRAM FILES\VOICEGUIDE\}[PathDataVm]{D:\PROGRAM FILES\VOICEGUIDE\data\}[PathVgSys]{D:\PROGRAM FILES\VOICEGUIDE\system\}[scriptsPath]{E:\SOFTWARE\VoiceGuide\KuanYinScripts\}[scriptPath]{E:\SOFTWARE\VoiceGuide\KuanYinScripts}[$RV_STARTTIME]{11/7/04 7:41:57 AM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{D:\PROGRAM FILES\VOICEGUIDE\}[$RV_CIDNUMBER]{}[Welcome]{1}[seeker]{4}[positiveORnegative]{1} 074214.13 0 rv replace end: [sELECT Phone FROM nameNphone WHERE [Group= 4 AND PositiveORnegative= 1]] 074214.13 0 db About to execute a Retrieve type operation [sELECT Phone FROM nameNphone WHERE [Group= 4 AND PositiveORnegative= 1]] 074214.13 0 OpenRecordset: 3061:Too few parameters. Expected 1. 074214.13 0 path {0} not found 074214.13 0 path {} not found 074214.13 0 timer clear 074214.13 0 [Error] Playing 074214.18 0 tts generate start[Jaibhom with great love from all of us here in the Pure Land of Buddha Amitabha. may everyone delight into the pure land of their pure mind.] 074214.18 0 tts generate wait 074214.18 0 RunModule PLAY end 074218.63 0 callstate DISCONNECTED 4328960 1 0 074218.63 0 ScriptEventCode 9250 iLineState=1100 074218.63 0 LsPlayMsg EV_REMOTEPARTY_DISCONNECT 074218.69 0 rv add [Hangup Time]{11/7/04 7:42:18 AM} 074218.69 0 Hanging up call... 074218.69 0 RecSoundStop ok 074218.69 0 PlaySoundStop err=0 074218.69 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 074218.69 0 fnHangupCall end 074218.91 0 callstate IDLE 4328960 0 0 074218.96 0 WorkingMode@Idle= 074218.96 0 timer clear 074218.96 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 074218.96 0 tapi Reply (LineEvReply) ok 2 0 074220.01 0 timer fired EV_TIMEOUT_TIMETOREINITLINE 074220.01 0 ScriptEventCode 9008 iLineState=900 074220.01 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 074220.01 0 ReinitTelephony due to IDLE 074220.01 0 tapic lineDeallocateCall(MainCall:4328960) 0 074223.47 0 lineOpen(0)=> 074223.47 0 Waiting for a call... 074223.47 0 LineHandle=4328640 074223.47 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 074224.07 0 dial start any summary:|0:rdy=0| 074225.11 0 dial start any summary:|0:rdy=0| 074226.16 0 dial start any summary:|0:rdy=0| 074226.82 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 074226.82 0 ScriptEventCode 9013 iLineState=900 074229.45 0 btn Exit (1 lines) 074229.45 0 line state =900 074229.45 0 Exiting... 074229.62 0 calling TapiWrap.Shutdown 074231.81 0 Unloading Main Window Share this post Link to post
SupportTeam Report post Posted 11/07/2004 05:46 AM I suspect that the problem is because you are using square brackets in your SQL statement: SELECT Phone FROM nameNphone WHERE [Group= 4 AND PositiveORnegative= 1] You should probably be using 'round brackets'... Share this post Link to post
Guest researcher Report post Posted 11/13/2005 08:21 AM Oh. Thanks. Your support is wonderfull. In a SQL statement not [ ] but ( ) brackets worked.Thanks. Share this post Link to post
