Dialogic Board
Can anyone help me identify my dialogic board? It has 1 rj45 connection, 1 rj11, and the following numbers; 85-0179-003 REV C . 83-0179-001. GT029728, T23980189. It appears to be ISA. There is only an fcc reg. no., not searchable.
If you can help please leave a response or email bhays2@eircom.net
I too have a dialogic card that appears very similiar to a cpi/100. However, a cpi/100 has a rj11 handset jack and wall jack. The one I have has a rj11 handset and a rj45 wall jack. That is the only difference I can tell. I will list as much information as I can get, here:
Underneath the plastic shielding, there is a small barcode with the numbers:
0179003K9AE38Q
It has a dialogic and conexant chipsets on the board:
Dialogic:
M10S0110-078
59-0687-100
9302101-B
Conexant:
R144EFXL
R6664-12
B83630.2
The number near the tail of the card is:
85-0179-003 REV. K
On the reverse of the card, is another barcode with id:
GT080853
I don't have any high-res photo's until the USB to mini-usb-b cable comes in that I ordered. This card was given to me under the assumption it was a cpi/100 fax card. I will keep tabs on this topic.
Really best to contact your local Dialogic reseller. They should be able to track down what card this is using the serial numbers you quote.
