adworld Report post Posted 11/09/2004 09:59 PM I am looking to get one or the other... either D/160SC LS or D/41H I will be running 48 lines... is there any real difference between the 2 boards other then the amount of lines they support? When you do a breakdown, they come out to about the same cost per line... My question is how can build a system that has 12 ISA cards in it? If I got D/41H I would need to get 12 cards... How can I design a setup with 12 cards to run off 1 version of VG? Thank you for your help!! David Share this post Link to post
SupportTeam Report post Posted 11/09/2004 10:46 PM I don't think you can easily build a computer these days which will support 12 ISA cards - I'd strongly suggest going ahead with the D/160SC LS. Share this post Link to post
