Cannot Evaluate An "or" Expression
I am assuming my syntax is incorrect when I try to evaluate this expression:
$RV[Enter #1] = 8 OR 6
This is the Event Trace Log Result:
220413.50 6 [Enter #1] Number Input
220413.52 6 [Enter #1] Playing (C:\Program Files\VoiceGuide\system\Voice Overs\3FOE1\1stnumber.wav)
220413.52 6 play set playid=447218
220413.61 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\Voice Overs\3FOE1\1stnumber.wav]
220413.61 6 timer clear
220413.63 6 wa(2499,44721800)
220413.63 6 callinfo MONITORMODES
220416.14 6 wb(44721800)
220416.25 6 play end current play (playid=447218)
220416.27 6 ScriptEventCode 8001 iLineState=1300
220416.27 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
220416.27 6 timer set 10 EV_TIMEOUT_HANGUP
220416.27 6 timer set 6 EV_TIMEOUT_ENTERDATA
220416.28 6 dtmf 8 (66474,56,2)
220416.28 6 ScriptEventCode 56 iLineState=1301
220416.30 6 LsGetNbrsRxDigits 8
220416.30 6 [Enter #1] Number Input 8
220416.30 6 path {8} not found
220416.31 6 timer set 6 EV_TIMEOUT_ENTERDATA
220416.31 6 timer clear
220416.31 6 rv add [Enter #1]{8}
220416.33 6 path {8} not found
220416.33 6 AddRVns [Enter #1_PathTaken]{success}
220416.33 6 timer clear
220416.33 6 [Enter #2] Number Input
220416.34 6 [Enter #2] Playing (C:\Program Files\VoiceGuide\system\Voice Overs\3FOE1\2ndnumber.wav)
220416.34 6 play set playid=450046
220416.42 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\Voice Overs\3FOE1\2ndnumber.wav]
220416.42 6 timer clear
220416.44 6 wa(1998,45004600)
220416.44 6 callinfo MONITORMODES
220418.44 6 wb(45004600)
220418.55 6 play end current play (playid=450046)
220418.55 6 ScriptEventCode 8001 iLineState=1300
220418.56 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
220418.56 6 timer set 10 EV_TIMEOUT_HANGUP
220418.56 6 timer set 6 EV_TIMEOUT_ENTERDATA
220418.95 6 dtmf 2 (66474,50,2)
220418.95 6 ScriptEventCode 50 iLineState=1301
220418.95 6 LsGetNbrsRxDigits 2
220418.97 6 [Enter #2] Number Input 2
220418.97 6 path {2} not found
220418.97 6 timer set 6 EV_TIMEOUT_ENTERDATA
220418.98 6 timer clear
220418.98 6 rv add [Enter #2]{2}
220418.98 6 path {2} not found
220419.00 6 AddRVns [Enter #2_PathTaken]{success}
220419.00 6 timer clear
220419.00 6 [Add Numbers] Evaluate [$RV[Enter #1] = 8 OR 6]
220419.00 6 rv replace start: [$RV[Enter #1] = 8 OR 6]
220419.02 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DNIS]{0000}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Chances Are Script\Test Scripts\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Chances Are Script\Test Scripts}[$RV_STARTTIME]{11/9/2004 10:04:13 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{ }[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Enter #1]{8}[Enter #1_PathTaken]{success}[Enter #2]{2}[Enter #2_PathTaken]{success}
220419.02 6 rv replace end: [8 = 8 OR 6]
220419.02 6 .Eval(8 = 8 OR 6)
220419.03 6 AddRVns [Add Numbers_Input]{8 = 8 OR 6}
220419.03 6 AddRVns [Add Numbers]{-1}
220419.03 6 Eval Expr result:[-1]
220419.05 6 path {-1} not found
220419.05 6 timer clear
220419.05 6 rv replace start: [$RV[Add Numbers]]
220419.06 6 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DNIS]{0000}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Chances Are Script\Test Scripts\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Chances Are Script\Test Scripts}[$RV_STARTTIME]{11/9/2004 10:04:13 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{ }[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Enter #1]{8}[Enter #1_PathTaken]{success}[Enter #2]{2}[Enter #2_PathTaken]{success}[Add Numbers_Input]{8 = 8 OR 6}[Add Numbers]{-1}
220419.06 6 rv replace end: [-1]
220419.06 6 [say Result] Say numbers: [-1] as Number
220419.08 6 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Voice Overs\you are the winner.wav],[],[-1],Number
220419.09 6 sVbsFunctionToUse=Number
220419.36 6 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs)
220419.39 6 cl Play_Start C:\Program Files\VoiceGuide\system\Voice Overs\you are the winner.wav,1.wav,minus.wav
220419.41 6 play set playid=453109
220419.55 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\Voice Overs\you are the winner.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\minus.wav]
220419.56 6 timer clear
220419.56 6 wa(5394,45310902)
220419.58 6 callinfo MONITORMODES
220425.00 6 wb(45310902)
220425.11 6 play end current play (playid=453109)
220425.11 6 ScriptEventCode 8001 iLineState=1600
220425.11 6 LsSayNbrPlay EV_PLAY_FINISHED
220425.13 6 timer set 10 EV_TIMEOUT_HANGUP
220428.83 0 btn Hangup on line 6
220428.83 6 ScriptEventCode 9001 iLineState=1600
220428.83 6 LsSayNbrPlay EV_TIMEOUT_HANGUP
220428.84 6 rv add [Hangup Time]{11/9/2004 10:04:28 PM}
220428.84 6 Hanging up call...
220428.86 6 RecSoundStop ok
220428.88 6 PlaySoundStop err=0
220428.88 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
220428.91 6 fnHangupCall end
220428.95 6 linedevstate 2048 0 0
220428.95 6 callstate IDLE 66474 0 0
220428.95 6 WorkingMode@Idle=
220428.97 6 timer clear
220428.98 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
220428.98 6 tapi Reply (LineEvReply) ok 66440 0
220430.00 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
220430.00 6 ScriptEventCode 9008 iLineState=900
220430.00 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
220430.02 6 ReinitTelephony due to IDLE
220430.02 6 tapic lineDeallocateCall(MainCall:66474) 0
220430.16 6 lineOpen(6)=>
220430.16 6 Waiting for a call...
I really want to evaluate something like this: $RV[Enter #1] = 8 OR 6 OR 2
But Voiceguide doesn't seem to pay attention to the "OR" operator. Why do I keep getting the wrong answers and what is the proper way to write this statement? How did Voiceguide evaluate this to get "-1"?
