Will Not Play Time When Read From Db
from an access database. Please help, Below is the log where it is suppose to play. I have tried every method in the Play numbers Module with no luck.
In1_3_1_2]{True}[Retrieve Emp In1_3_1_3]{True}
204707.16 9 rv replace end: [6:57:00 PM]
204707.17 9 [say time In1] Say numbers: [6:57:00 PM] as Date & Time - MMDDHHNN
204707.17 9 fn PlaySoundStartNumbers [],[],[6:57:00 PM],Date & Time - MMDDHHNN
204707.17 9 sVbsFunctionToUse=DateTimeMMDDHHNN
204707.22 9 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_9_SayNumber.vbs)
204707.31 9 cl Play_Start
Please help
Erich
"6:57:00 PM" is not in format: "MMDDHHNN' - that's why Voiceguide is not saying it right...
Try placing attached file in VoiceGuide 's \system\vbs\ subdirectory,
Stop VoiceGuide then start the script designer - select the "Time - HH:NN:SS AM/PM" option in the "Say numbers as:" dropdown combo box, save the script and start VoiceGuide and try dialing in again.
(have a look at lib_num2wav.vbs to see how you can add functions to it to allow VoiceGuide to say just about any incoming date/time format)
lib_num2wav.vbs
Time is still a no go. I fixed the date problem in the vbs file but can not get the time on figured out. It still does not want to read the time. Nothing is done. Here is the current log section.
021811.00 9 rv replace end: [8:27:00 PM]
021812.01 9 [say time In1] Say numbers: [8:27:00 PM] as Time - HH:NN:SS AM/PM
021812.01 9 fn PlaySoundStartNumbers [],[],[8:27:00 PM],Time - HH:NN:SS AM/PM
021812.03 9 sVbsFunctionToUse=DateTimeLongTime
021812.11 9 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_9_SayNumber.vbs)
021812.20 9 cl Play_Start
021812.22 9 ScriptEventCode 8001 iLineState=1600
021812.22 9 LsSayNbrPlay EV_PLAY_FINISHED
Sorry it took so long to get back. Yes that worked great. I have attached another vbs file because your date was part was still backwards. In both sections of the file MMDDYYYY and DDMMYYYY you got it reading DDMMYYYY I corrected the MMDDYYYY and is in the attached file. Thanks for all of your help.
Erich
lib_num2wav.vbs
