ishola Report post Posted 11/18/2004 09:16 AM I just started using VG. When i use the outbound facility, it takes a long time like 20sec to start playing playing my .wav file after the recipiet has picked up the line. so i have recipents that will have to waite for all that time to hear the message. What am i doing wrong? I am using D/4PCI, with SR5.11 with SP1 Ishola Share this post Link to post
SupportTeam Report post Posted 11/18/2004 10:03 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
ishola Report post Posted 11/18/2004 10:53 PM 234055.05 5 dial [61,12,411182337,1,2359,MoTuWeThFrSaSu,,2,NONE,D:\Voice Files\mayor.wav,D:\Voice Files\mayor.wav,none,45,2,120,,none] 234055.05 0 dial callque update id=61 next call time 0411190140 234055.06 0 dial callque DB update returned 234055.06 5 dial found entry: tel[12] ann[NONE] vgs[D:\Voice Files\mayor.wav] am[D:\Voice Files\mayor.wav] 234055.06 5 Dialing: 12 234055.06 5 MakeCall => 65553 234055.06 5 timer set 45 EV_TIMEOUT_MAKECALL_NORESPONSE 234055.06 5 TapiCbTrigSet 65553 7002 234055.06 0 dial start any summary:|5:dial=0| 234056.06 0 dial start any summary:|5:rdy=0| 234056.20 5 tapi Reply (LineEvReply) ok 65553 0 234056.20 5 TapiCbTrigClear 234056.20 5 linedevstate 2048 0 0 234056.20 5 callstate DIALTONE 66509 0 0 234056.20 5 callstate DIALING 66509 0 0 234056.20 5 callstate PROCEEDING 66509 0 0 234056.20 5 callinfo CALLEDID 234056.20 5 callinfo REASON 234056.39 5 Lev_CallerID [0000,,12] 234056.39 5 rv add [DNIS]{12} 234056.39 5 callinfo ORIGIN 234108.80 5 callstate DISCONNECTED 66509 16 0 234108.80 5 ScriptEventCode 9250 iLineState=5200 234108.80 5 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT 234108.80 5 rv add [OutDial_RetriesLeft]{2} 234108.80 5 rv add [$RV_STARTTIME]{11/18/2004 11:41:08 PM} 234108.80 5 rv add [$RV_DEVICEID]{5} 234108.80 5 rv add [$RV_CIDNAME]{} 234108.80 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 234108.80 5 rv add [$RV_CALLEDNUMBER]{12} 234108.80 0 dial callque delete id=61 234108.81 5 AddRVns [OutDial_Result]{Contacted_AM} 234108.81 5 AM - wait for end of welcome message... 234108.81 5 dial awaiting end of answering machine message (lvl:10 for 20) 234108.81 5 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_5.wav] ok 234108.81 5 timer set 120 EV_TIMEOUT_HANGUP 234111.91 5 ScriptEventCode 9300 iLineState=1152 234111.91 5 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED 234111.97 5 RecSoundStop ok 234111.97 5 timer set 1 EV_REC_FINISHED 234111.97 5 ScriptEventCode 8003 iLineState=1152 234111.97 5 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED 234111.97 5 rv replace start: [$RV[AmWelcMsg_RecLen100ms]] 234111.97 5 rv ns none[OutDial_RetriesLeft]{2} 234111.97 5 rv replace end: [] 234111.97 5 am msglen=0, minrequired=20 234111.97 5 Play Answer Machine message [D:\Voice Files\mayor.wav] 234111.97 5 play set playid=577828 234112.02 5 PlaySoundStart ok [D:\Voice Files\mayor.wav] 234112.02 5 timer clear 234112.02 5 wa(26559,57782800) 234138.58 5 wb(57782800) 234138.64 5 play end current play (playid=577828) 234138.64 5 ScriptEventCode 8001 iLineState=1153 234138.64 5 LsDialoutPlayOnAnswerMachine EV_PLAY_FINISHED 234138.64 5 rv add [Hangup Time]{11/18/2004 11:41:38 PM} 234138.64 5 Hanging up call... [LsDialoutPlayOnAnswerMachine 2 ] 234138.64 5 RecSoundStop ok 234138.64 5 PlaySoundStop err=0 234138.64 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 234138.66 5 Waiting for a call... 234138.67 5 fnHangupCall end 234138.69 5 linedevstate 2048 0 0 234138.69 5 callstate IDLE 66509 0 0 234138.70 5 WorkingMode@Idle= 234138.70 5 timer clear 234138.70 5 LineState(iLineId).iVgsIdx = 0 234138.70 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 234138.70 5 tapi Reply (LineEvReply) ok 66526 0 234139.77 5 timer fired EV_TIMEOUT_TIMETOREINITLINE 234139.77 5 ScriptEventCode 9008 iLineState=900 234139.77 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 234139.77 5 ReinitTelephony due to IDLE 234139.77 5 tapic lineDeallocateCall(MainCall:66509) 0 234139.92 5 lineOpen(5)=> 234139.94 5 Waiting for a call... 234139.94 5 LineHandle=66475 234139.94 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 234140.06 0 dial start any summary:|5:rdy=0| 234141.06 0 dial start any summary:|5:rdy=0| 234142.06 0 dial start any summary:|5:rdy=0| 234143.06 0 dial start any summary:|5:rdy=0| 234143.22 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 234143.22 5 ScriptEventCode 9013 iLineState=900 Share this post Link to post
SupportTeam Report post Posted 11/18/2004 11:40 PM Trace shows VG started dialing number at: 23:40:56 234056.20 5 callstate DIALING 66509 0 0 Then 16 seconds later Dialogic card reported that it has heard an Answering Machine answer the call: 234108.81 5 AM - wait for end of welcome message... and then 3 seconds later it started playing the message mayor.wav 234111.97 5 Play Answer Machine message [D:\Voice Files\mayor.wav] On poor quality lines the Dialogic card sometimes mistakenly thinks that an answering machine has answered the call - looks like this is happening in this case... Share this post Link to post
