Guest Hal Netkin Report post Posted 05/03/2003 06:26 AM Running v4.9.0 How do I turn off the automatic answering? I just want to voice broadcast dial out without receiving calls. Hal Netkin Share this post Link to post
SupportTeam Report post Posted 05/03/2003 08:02 AM You can set the "Rings before answering incoming call" to a high number. Fron View menu select Line Device Config (that settings max value is 20 is max at this stage - and 99 in v4.9.1) Share this post Link to post
Guest Hal Netkin Report post Posted 05/05/2003 04:40 PM Are you saying that there is not way to shut off incoming calls? Hal Netkin Share this post Link to post
SupportTeam Report post Posted 05/07/2003 05:20 AM If you set the number of rings to a high number that will effectively stop any calls from being answered... Share this post Link to post
