Answering
Running v4.9.0
How do I turn off the automatic answering? I just want to voice broadcast dial out without receiving calls.
Hal Netkin
You can set the "Rings before answering incoming call" to a high number.
Fron View menu select Line Device Config
(that settings max value is 20 is max at this stage - and 99 in v4.9.1)
Are you saying that there is not way to shut off incoming calls?
Hal Netkin
If you set the number of rings to a high number that will effectively stop any calls from being answered...
