Vbs Validation Of Entered Numbers
I copied this script from help to validate if entered numbers begins with 0 and takes long about 11.
iLen = Len("$RV_ENTEREDNUMBER")
sFirstChar = Left("$RV_ENTEREDNUMBER",1)
if iLen<10 or iLen>11 or sFirstChar <> "0" then
sResult = "verify_failed"
else
sResult = "verify_passed"
end i
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
after entering numbers I got debug error on vg program
that in the line 8 char 5 (or sometimes other char)
"If expected".
error code= here some numbers.
Is the script wrong?
I am working on windows 2000 server. Do I have to install some additional soft from microsoft to make server understand vbs from vg?
Just look at line 8 of your script, it says:
end i
This is invalid syntax - you should have used just "end" on this line. The error message even tells you that the problem ocurrs on the 5th character of the line...
Yes, quite correct, it should actually be "end if". Will fix the help file as well.
