Error Messages From Voiceguide
All,
When I start VoiceGuide and open the messages window I see the following messages displayed:
Error Messages from VoiceGuide[91:Object variable or With block variable not set]
120308.69 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120308.70 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120309.75 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120309.77 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120309.80 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120309.83 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120310.11 0 ERROR 5.2.3018 EmailDbQueue_CountDueEmails CreateQueryDef [91:Object variable or With block variable not set]
120310.84 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120310.88 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120310.89 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120310.92 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120312.41 0 ERROR 5.2.3018 EmailDbQueue_CountDueEmails CreateQueryDef [91:Object variable or With block variable not set]
120312.50 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120312.59 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120312.70 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120312.80 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120313.91 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120314.02 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120314.11 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
120314.22 0 ERROR 5.2.3018 dial FindDueCall CreateQueryDef [91:Object variable or With block variable not set]
This is a portion of what keeps scrolling through the window.
This error happens with our custom script and the collections script provided by Voice Guide.
Any ideas or suggestions would be appreciated.
Steve
Please stop VoiceGuide, then delete file OutDialQue.mdb in VG's \data\ subdirectory then start VG again.
