Guest halyal Report post Posted 05/05/2003 05:22 AM I will be developing the application for the customer on my machine and then transferring the software to customer machine. As I have read in the documents the software will be lic on the network card the onboard network card cannot be transferred. Rajesh Share this post Link to post
SupportTeam Report post Posted 05/07/2003 05:19 AM You can develop the application using the evaluation version of VoiceGuide - starting with v4.9 there are no limits on the number of modules that you can use or on the features - you will just need to restart VoiceGuide every hour which is usually fine for development. (the script designer does not need to be restarted - you can use this without interruptions) Share this post Link to post
