Problem With Blind Transfer Same Digit
I use voiceguide with autoattendant.vgs script, it is ok when transfer to ext number 123, 134, 121.., but when transfer to ext number 112, 122 or 223 (the same two digit continue) it not ringing, it seem the PBX just receive 12, 12 or 23. Could you tell me about the problem. Thanks
I sent the printout. when I dial 360, it is ok; but when dial 355, the ext not ringing. Please tell me what is the problem. Thanks
164851.77 8 callstate OFFERING 66510 0 4
164851.78 8 ring 1
164851.78 8 Terminating process (new call).
164851.78 8 Answer the call at 12-13-2004 4:48:51 PM
164851.78 8 lineAnswer(66510) => 66527
164851.80 8 callstate ACCEPTED 66510 0 0
164854.86 8 tapi Reply (LineEvReply) ok 66527 0
164854.89 8 callstate CONNECTED 66510 0 0
164854.89 8 callstate CONNECTED 66510,0,0
164854.89 8 WorkingModeTAPI@Connected=
164854.89 8 WorkingModeScript@Connected=
164854.91 8 Inband detection not enabled
164854.91 8 StartLoadedVgs at 12-13-2004 4:48:54 PM
164854.91 8 AddRVns [scriptsPath]{C:\}
164854.91 8 AddRVns [scriptPath]{C:}
164854.91 8 rv add [$RV_STARTTIME]{12-13-2004 4:48:54 PM}
164854.92 8 rv add [$RV_DEVICEID]{8}
164854.92 8 rv add [$RV_CIDNAME]{}
164854.92 8 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
164854.92 8 rv add [$RV_CIDNUMBER]{}
164854.94 8 timer clear
164854.94 8 [Welcome] Number Input
164854.94 8 [Welcome] Playing (Support\AutoAttendant\recordings\welcome msg_8k16bitMono.wav)
164854.94 8 play set playid=438484
164855.16 8 PlaySoundStart ok [support\AutoAttendant\recordings\welcome msg_8k16bitMono.wav]
164855.16 8 timer clear
164855.17 8 wa(15497,43848400)
164910.63 8 play end current play (playid=438484)
164910.63 8 ScriptEventCode 8001 iLineState=1300
164910.63 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
164910.63 8 timer set 5 EV_TIMEOUT_REPLAYMSG
164910.75 8 dtmf 3 (66510,51,2)
164910.77 8 ScriptEventCode 51 iLineState=1301
164910.77 8 LsGetNbrsRxDigits 3
164910.77 8 [Welcome] Number Input 3
164910.77 8 path {3} not found
164910.78 8 timer set 6 EV_TIMEOUT_ENTERDATA
164911.11 8 dtmf 6 (66510,54,2)
164911.13 8 ScriptEventCode 54 iLineState=1301
164911.13 8 LsGetNbrsRxDigits 6
164911.13 8 [Welcome] Number Input 36
164911.13 8 path {36} not found
164911.14 8 timer set 6 EV_TIMEOUT_ENTERDATA
164911.53 8 dtmf 0 (66510,48,2)
164911.55 8 ScriptEventCode 48 iLineState=1301
164911.55 8 LsGetNbrsRxDigits 0
164911.55 8 [Welcome] Number Input 360
164911.55 8 path {360} not found
164911.56 8 timer set 6 EV_TIMEOUT_ENTERDATA
164911.56 8 timer clear
164911.56 8 rv add [Welcome]{360}
164911.56 8 eng run verification
164911.56 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
iLen = Len("$RV_ENTEREDNUMBER")
sFirstChar = Left("$RV_ENTEREDNUMBER",1)
if iLen > 3 then
sResult = "verify_failed"
else
sResult = "verify_passed"
end if
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
164911.58 8 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\}[scriptPath]{C:}[$RV_STARTTIME]{12-13-2004 4:48:54 PM}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{360}
164911.58 8 eng copy of verification script ran: vbs_8_1.vbs
164911.59 8 Run Script waiting... (shellid=480, process=892)
164911.61 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
164911.67 8 cl Run_ResultReturn >>verify_passed<<
164911.67 8 ScriptEventCode 9221 iLineState=1301
164911.67 8 LsGetNbrsRxDigits EV_UNKNOWN_9221
164911.67 8 eng GetNbr EV_MODGETNBRS_VERIFY_PASS
164911.69 8 path {360} not found
164911.69 8 AddRVns [Welcome_PathTaken]{success}
164911.69 8 timer clear
164911.69 8 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
164912.06 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
164912.06 8 ScriptEventCode 9012 iLineState=1900
164912.06 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
164912.06 8 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
164912.08 8 rv replace start: [$RV_ENTEREDNUMBER]
164912.08 8 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\}[scriptPath]{C:}[$RV_STARTTIME]{12-13-2004 4:48:54 PM}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{360}[Welcome_PathTaken]{success}
164912.08 8 rv replace end: [360]
164912.08 8 [Transfer Call 6] Blind Transfer to 360 (Generate)
164912.09 8 tapic lineGenerateDigits(66510,!,0) => 0
164912.61 8 generate LINEGENERATETERM_DONE
164912.64 8 timer set 1 EV_TAPI_GENERATE
164913.63 8 timer fired EV_TAPI_GENERATE
164913.63 8 ScriptEventCode 9602 iLineState=1900
164913.63 8 LsXferStart EV_TAPI_GENERATE
164913.63 8 timer set 1 EV_HOOKFLASHFINISHED
164914.73 8 timer fired EV_HOOKFLASHFINISHED
164914.73 8 ScriptEventCode 9200 iLineState=1905
164914.73 8 LsXferPlayVts EV_HOOKFLASHFINISHED
164914.73 8 tapic lineGenerateDigits(66510,360,0) => 0
164915.03 8 dtmf 6 (66510,54,2)
164915.03 8 ScriptEventCode 54 iLineState=1905
164915.05 8 LsXferPlayVts 6
164915.11 8 generate LINEGENERATETERM_DONE
164915.11 8 timer set 1 EV_TAPI_GENERATE
164915.16 8 dtmf 0 (66510,48,2)
164915.19 8 ScriptEventCode 48 iLineState=1905
164915.19 8 LsXferPlayVts 0
164916.19 8 timer fired EV_TAPI_GENERATE
164916.19 8 ScriptEventCode 9602 iLineState=1905
164916.19 8 LsXferPlayVts EV_TAPI_GENERATE
164916.19 8 timer set 3 EV_TIMEOUT_HANGUP
164919.48 8 timer fired EV_TIMEOUT_HANGUP
164919.48 8 ScriptEventCode 9001 iLineState=1905
164919.48 8 LsXferPlayVts EV_TIMEOUT_HANGUP
164919.48 8 rv add [Hangup Time]{12-13-2004 4:49:19 PM}
164919.50 8 Hanging up call...
164919.50 8 RecSoundStop ok
164919.52 8 PlaySoundStop err=0
164919.52 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
164919.53 8 fnHangupCall end
164919.67 8 callstate DISCONNECTED 66510 1 0
164919.67 8 ScriptEventCode 9250 iLineState=900
164919.67 8 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
164919.69 8 rv add [Hangup Time]{12-13-2004 4:49:19 PM}
164919.69 8 Hanging up call...
164919.69 8 RecSoundStop ok
164919.70 8 PlaySoundStop err=0
164919.70 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
164919.72 8 fnHangupCall end
164919.72 8 callstate IDLE 66510 0 0
164919.73 8 WorkingMode@Idle=
164919.73 8 timer clear
164919.73 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
164919.75 8 tapi Reply (LineEvReply) ok 65622 0
164919.75 8 tapi Reply (LineEvReply) ok 65639 0
164920.73 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
164920.73 8 ScriptEventCode 9008 iLineState=900
164920.73 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
164920.73 8 ReinitTelephony due to IDLE
164920.75 8 tapic lineDeallocateCall(MainCall:66510) 0
164920.86 8 lineOpen(8)=>
164920.86 8 Waiting for a call...
164920.86 8 LineHandle=66528
164920.88 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
164921.20 0 dial start any summary:|8:rdy=0|
164922.20 0 dial start any summary:|8:rdy=0|
164923.20 0 dial start any summary:|8:rdy=0|
164924.16 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
164924.16 8 ScriptEventCode 9013 iLineState=900
164933.41 8 callstate OFFERING 65963 0 4
164933.41 8 ring 1
164933.42 8 Terminating process (new call).
164933.42 8 Answer the call at 12-13-2004 4:49:33 PM
164933.42 8 lineAnswer(65963) => 66459
164933.44 8 callstate ACCEPTED 65963 0 0
164936.52 8 tapi Reply (LineEvReply) ok 66459 0
164936.53 8 callstate CONNECTED 65963 0 0
164936.53 8 callstate CONNECTED 65963,0,0
164936.55 8 WorkingModeTAPI@Connected=
164936.55 8 WorkingModeScript@Connected=
164936.55 8 Inband detection not enabled
164936.56 8 StartLoadedVgs at 12-13-2004 4:49:36 PM
164936.56 8 AddRVns [scriptsPath]{C:\}
164936.59 8 AddRVns [scriptPath]{C:}
164936.59 8 rv add [$RV_STARTTIME]{12-13-2004 4:49:36 PM}
164936.63 8 rv add [$RV_DEVICEID]{8}
164936.63 8 rv add [$RV_CIDNAME]{}
164936.63 8 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
164936.63 8 rv add [$RV_CIDNUMBER]{}
164936.64 8 timer clear
164936.64 8 [Welcome] Number Input
164936.66 8 [Welcome] Playing (Support\AutoAttendant\recordings\welcome msg_8k16bitMono.wav)
164936.66 8 play set playid=480203
164936.86 8 PlaySoundStart ok [support\AutoAttendant\recordings\welcome msg_8k16bitMono.wav]
164936.86 8 timer clear
164936.88 8 wa(15497,48020300)
164952.36 8 play end current play (playid=480203)
164952.38 8 ScriptEventCode 8001 iLineState=1300
164952.38 8 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
164952.38 8 timer set 5 EV_TIMEOUT_REPLAYMSG
164952.50 8 dtmf 3 (65963,51,2)
164952.50 8 ScriptEventCode 51 iLineState=1301
164952.50 8 LsGetNbrsRxDigits 3
164952.50 8 [Welcome] Number Input 3
164952.52 8 path {3} not found
164952.52 8 timer set 6 EV_TIMEOUT_ENTERDATA
164952.88 8 dtmf 5 (65963,53,2)
164952.88 8 ScriptEventCode 53 iLineState=1301
164952.88 8 LsGetNbrsRxDigits 5
164952.89 8 [Welcome] Number Input 35
164952.89 8 path {35} not found
164952.89 8 timer set 6 EV_TIMEOUT_ENTERDATA
164953.14 8 dtmf 5 (65963,53,2)
164953.14 8 ScriptEventCode 53 iLineState=1301
164953.16 8 LsGetNbrsRxDigits 5
164953.16 8 [Welcome] Number Input 355
164953.16 8 path {355} not found
164953.16 8 timer set 6 EV_TIMEOUT_ENTERDATA
164953.17 8 timer clear
164953.17 8 rv add [Welcome]{355}
164953.17 8 eng run verification
164953.17 8 rv replace start: [set vg = CreateObject("VoiceGuide.CommandLink")
if iLen > 3 then
else
end if
set vg = Nothing
164953.19 8 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\}[scriptPath]{C:}[$RV_STARTTIME]{12-13-2004 4:49:36 PM}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{355}
164953.19 8 eng copy of verification script ran: vbs_8_1.vbs
164953.20 8 Run Script waiting... (shellid=216, process=776)
164953.22 8 timer set 1 EV_TIMEOUT_CHECKONSTATE
164953.27 8 cl Run_ResultReturn >>verify_passed<<
164953.28 8 ScriptEventCode 9221 iLineState=1301
164953.28 8 LsGetNbrsRxDigits EV_UNKNOWN_9221
164953.28 8 eng GetNbr EV_MODGETNBRS_VERIFY_PASS
164953.30 8 path {355} not found
164953.33 8 AddRVns [Welcome_PathTaken]{success}
164953.34 8 timer clear
164953.34 8 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
164953.77 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
164953.77 8 ScriptEventCode 9012 iLineState=1900
164953.77 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
164953.78 8 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
164953.80 8 rv replace start: [$RV_ENTEREDNUMBER]
164953.80 8 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\}[scriptPath]{C:}[$RV_STARTTIME]{12-13-2004 4:49:36 PM}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{355}[Welcome_PathTaken]{success}
164953.81 8 rv replace end: [355]
164953.83 8 [Transfer Call 6] Blind Transfer to 355 (Generate)
164953.83 8 tapic lineGenerateDigits(65963,!,0) => 0
164954.36 8 generate LINEGENERATETERM_DONE
164954.36 8 timer set 1 EV_TAPI_GENERATE
164955.36 8 timer fired EV_TAPI_GENERATE
164955.36 8 ScriptEventCode 9602 iLineState=1900
164955.36 8 LsXferStart EV_TAPI_GENERATE
164955.36 8 timer set 1 EV_HOOKFLASHFINISHED
164956.47 8 timer fired EV_HOOKFLASHFINISHED
164956.47 8 ScriptEventCode 9200 iLineState=1905
164956.47 8 LsXferPlayVts EV_HOOKFLASHFINISHED
164956.47 8 tapic lineGenerateDigits(65963,355,0) => 0
164956.75 8 dtmf 5 (65963,53,2)
164956.77 8 ScriptEventCode 53 iLineState=1905
164956.77 8 LsXferPlayVts 5
164956.83 8 generate LINEGENERATETERM_DONE
164956.84 8 timer set 1 EV_TAPI_GENERATE
164957.91 8 timer fired EV_TAPI_GENERATE
164957.91 8 ScriptEventCode 9602 iLineState=1905
164957.91 8 LsXferPlayVts EV_TAPI_GENERATE
164957.91 8 timer set 3 EV_TIMEOUT_HANGUP
165001.20 8 timer fired EV_TIMEOUT_HANGUP
165001.20 8 ScriptEventCode 9001 iLineState=1905
165001.20 8 LsXferPlayVts EV_TIMEOUT_HANGUP
165001.20 8 rv add [Hangup Time]{12-13-2004 4:50:01 PM}
165001.22 8 Hanging up call...
165001.22 8 RecSoundStop ok
165001.23 8 PlaySoundStop err=0
165001.23 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
165001.25 8 fnHangupCall end
165001.39 8 callstate DISCONNECTED 65963 1 0
165001.39 8 ScriptEventCode 9250 iLineState=900
165001.41 8 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
165001.41 8 rv add [Hangup Time]{12-13-2004 4:50:01 PM}
165001.41 8 Hanging up call...
165001.42 8 RecSoundStop ok
165001.42 8 PlaySoundStop err=0
165001.44 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
165001.44 8 fnHangupCall end
165001.45 8 callstate IDLE 65963 0 0
165001.45 8 WorkingMode@Idle=
165001.45 8 timer clear
165001.47 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
165001.47 8 tapi Reply (LineEvReply) ok 66476 0
165001.47 8 tapi Reply (LineEvReply) ok 66408 0
165002.47 8 timer fired EV_TIMEOUT_TIMETOREINITLINE
165002.47 8 ScriptEventCode 9008 iLineState=900
165002.47 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
165002.47 8 ReinitTelephony due to IDLE
165002.48 8 tapic lineDeallocateCall(MainCall:65963) 0
165002.67 8 lineOpen(8)=>
165002.67 8 Waiting for a call...
165002.67 8 LineHandle=66425
165002.67 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
165003.27 0 dial start any summary:|8:rdy=0|
165004.27 0 dial start any summary:|8:rdy=0|
165005.27 0 dial start any summary:|8:rdy=0|
165005.97 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
165005.97 8 ScriptEventCode 9013 iLineState=900
It appears as if whenever the same DTMF tone number is sent to the PBX twice the PBX thinks it has only heard one tone number.
Looks like the PBX's DTMF tone detection 'debounce' timing is set too long.
Alternatively you could just increase the time between the individual DTMF tone numbers played. This can be done by changing the config of the Dialogic card, or by inserting commas in between the individual digits to be dialed.
Are you using a Dialogic card or a voice modem?
I'm using voice modem; but when I insert commas the PBX receive another number, ex I want to dial 350 and change to 3,5,0 after that the ext 135 ringing
