Compare Date Different From Database
Hi all,
I use the DateDiff VbFunction in Evalute Expression Module but always return true, can anyone can help me to solve this problem?
'' Let said the record in database of [Get SM Record_2_1] is 1/1/2005, and it's stored in a Data/Time Data Type in access.
Here is Expression,
DateDiff("d", CDate($RV[Get SM Record_2_1]), Date) > 0
And Here is the Log
133841.91 0 [Check SM Card Expiry Date] Evaluate [DateDiff("d", CDate($RV[Get SM Card Record_2_1]), Date) > 0]
133841.91 0 rv replace start: [DateDiff("d", CDate($RV[Get SM Card Record_2_1]), Date) > 0]
133841.91 0 rv replace end: [DateDiff("d", CDate(1/1/2005), Date) > 0]
133841.91 0 .Eval(DateDiff("d", CDate(1/1/2005), Date) > 0)
133841.91 0 AddRVns [Check SM Card Expiry Date_Input]{DateDiff("d", CDate(1/1/2005), Date) > 0}
133841.91 0 AddRVns [Check SM Card Expiry Date]{True}
133841.92 0 Eval Expr result:[True]
The CDate function expects a string input.
Your expression should be:
DateDiff("d", CDate("$RV[Get SM Record_2_1]"), Date) > 0
notice the quotes around the RV...
