Recorded File Lost
My script is set up to make outbound calls, and record a message from the person called. This is using the RECORD module. They are instructed to hit # when done, so that it continues in the script, however if they hang up when they are in this record module VG will NOT save the file.
I tried to use the on 1 goto voicemail box 1 path, BUT this always asks for a mailbox number, which is not part of my script and is obviosley not known to the user on the phone. The goto voicemail box 1 and goto voicemail box menu go to the same voice promtp, IE to enter the voice mail box number.
I would use the voice mail box go to command if that worked, which seems to save the recorded file even if someone hangs up and does not press #
Or is there some other way to do this?
There should be no issues in the Record module not saving the file - the file is created when the recording is started and the file is just added to as recording progresses...
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
2.
Voicemail boxes should be at least two digits long - try defining a voicemail box "01" and set
your path to be:
On {1} Goto [Voicemail Box 01]
