How Delete Callque Database In A Script
Hello everybody,
I try to delete all the CallQue table in a script.
- I am using the Query database module.
- Under "Database or ODBC source" I put C:\Program Files\VoiceGuide\data\OutDialQue.mdb where my file is located.
- Under "connect string" I put nothing
- For my query I wrote this request to delete completely the entries and DayTimeStart in my case is really 0 in all the table...
SELECT '*' FROM CallQue WHERE DayTimeStart='0'
Can somebody could please tell me what is wrong because the database won't delete (flush).
P.S. The entries to record some stuff in the database is bellow (it work)
const numero1="668,0"
const numero2="667,0"
const numero3="692,0"
const numero4="698,0"
const numero5="653,0"
Const script_to_execute="C:\Program Files\VoiceGuide\Scripts\Answer and Record\alarm.vgs"
vg.Dialer_OutDialQueAdd numero1, 0, 0, 0, "", "", 1, "", script_to_execute,"","[CustomerID]{44563}", 0, 2, 1, ""
set vg = Nothing
vg.Dialer_OutDialQueAdd numero2, 0, 0, 0, "", "", 1, "", script_to_execute,"","[CustomerID]{44563}", 0, 2, 1, ""
set vg = Nothing
vg.Dialer_OutDialQueAdd numero3, 0, 0, 0, "", "", 1, "", script_to_execute,"","[CustomerID]{44563}", 0, 2, 1, ""
set vg = Nothing
vg.Dialer_OutDialQueAdd numero4, 0, 0, 0, "", "", 1, "", script_to_execute,"","[CustomerID]{44563}", 0, 2, 1, ""
set vg = Nothing
vg.Dialer_OutDialQueAdd numero5, 0, 0, 0, "", "", 1, "", script_to_execute,"","[CustomerID]{44563}", 0, 2, 1, ""
set vg = Nothing
Well sorry outside of SELECT I used
DELETE '*' FROM CallQue WHERE DayTimeStart='0'
but the effect is the same :) ... nothing is deleted
DayTimeStart is a number field not a string field, so your SQL statement should probably be:
DELETE FROM CallQue WHERE DayTimeStart=0
I don’t think you should be specifying '*' after DELETE either...
Well what you gave doesn't work but I finally found a script toto.vbs who do what I need... So Please find the details bellow of my .vbs if there is others people who have the same needs...
Dim objCon ' A Connection Object for database connectivity
Dim objRS ' A Recordset Object for database connectivity
Dim sProviderName ' The OLE Provider Type
Dim iCursorType ' The Cursor Type for the Recordset
Dim iLockType ' The Lock Type for the Recordset
Dim sDataSource ' The name and location of the database
Dim intCompID ' A computer ID asssigned when the computer is added to the database
Dim intRam ' The amount of RAM in the computer.
call subConnectionOpen
call deleteall
call subConnectionClose
Sub subConnectionOpen
Set objCon = CreateObject("ADODB.Connection")
Set objRS = CreateObject("ADODB.Recordset")
sProviderName = "Microsoft.Jet.OLEDB.4.0"
iCursorType = 1
iLockType = 3
sDataSource = "c:\OutDialQue.mdb"
objCon.Provider = sProviderName
objCon.Properties("Data Source") = sDataSource
objCon.Open
End Sub
Sub subConnectionClose
set objRS = nothing
set objCon = nothing
End Sub
Sub deleteall
objRS.CursorType = iCursorType
objRS.LockType = iLockType
objRS.Source = "CallQue"
objRS.ActiveConnection = objCon
objRS.Open
Do While Not objRS.EOF
objRS.delete
objRS.Update
objRS.MoveNext
Loop
objRS.Close
end sub
Well finally because I had lot of difficulties with the dialer I made few scripts to
-1- Delete the complete mdb access database dialer
-2- Add entries in the dialer from a scenario
It work very well but I'm sure it could be still improved so I would like to share that with everybody to spare lot of time to the users. (the modem is a fritz card ISDN who work very well with TTS too). Have fun!
-----1 DELETE THE COMPLETE DIALER DATABASE----
call deleteall
'wscript.echo "DELETED"
iCursorType = 1
iLockType = 3
sDataSource = "C:\Program Files\VoiceGuide\data\OutDialQue.mdb"
objCon.Open
End Sub
set objRS = nothing
End Sub
Sub deleteall
objRS.Open
objRS.delete
objRS.Update
objRS.MoveNext
Loop
objRS.Close
end sub
-----2 ADD TWO ENTRIES IN THE DIALER--------
const numero1="5550065"
const numero2="5550066"
call addentry1
call addentry2
iCursorType = 1
iLockType = 3
objCon.Open
End Sub
set objRS = nothing
End Sub
Sub addentry1
objRS.Open
objRS.addnew
objRS.Fields("PhoneNumber") = numero1
objRS.Fields("ActivateTime") = 501122129
objRS.Fields("DayTimeStart") = 1
objRS.Fields("DayTimeStop") =2359
objRS.Fields("DaysCallAllowed") ="MoTuWeThFrSaSu"
objRS.Fields("LineSelection") =""
objRS.Fields("Priority") =2
objRS.Fields("AnnounceMessage") ="NONE"
objRS.Fields("Script") =script_to_execute
objRS.Fields("OnAnswerMachine") ="NONE"
objRS.Fields("RV") ="none"
objRS.Fields("AnswerTimeout") =60
objRS.Fields("CallRetriesLeft") =2
objRS.Fields("DelayBetweenRetries") =120
objRS.Fields("OnNotConnected") =""
objRS.Fields("EscalationCalls") ="none"
objRS.update
objRS.Close
end sub
Sub addentry2
objRS.Open
objRS.addnew
objRS.Fields("PhoneNumber") = numero2
objRS.update
objRS.Close
end sub
