Identify Called Numbers
Hello,
I'm looking for a way to identify which 800 has been called in my system through a vgs script. I have 2 800 numbers pointing to my card but I can't seem to detect which number is being called in my vgs script. I turned on the logging as well to see if i can see it in the log but it doesn't seem to get logged there either.
Any assistance would be appriciated,
Rob
Are you using analog or digital lines?
Usually to find out the number dialed by caller you would need to be using ISDN lines.
On analog lines you would have to have the phone company send this info using Inband Signaling. Ask them if this is possible. If not then you will need to get a digital ISDN line.
