Hung Up
Hello I have major problem with Voice Guide. it keep hung up on my customer while it is process there credit card. the major problem is that the data base get incomplete info and we can not tell why the balance is not match with paid and pay amount.
I have reported this problem before and Admin told me, that I need to change the Disc1 and Disc2 freq in dialogic board configuration.
I reduce and increase the Disc1 and 2 freq and test them, but in both case scrip keep hung up on me.
Below is the Log file from one of the disconnect transaction. Please let me know if i have to increase the Disc freq or increase the disc freq in dialogic configuration. Also please let me know to what should I change it.
Please let me know if my problem is a common problem for everyone. if it is not perhaps I have a problem with my dialogic board or my computer!
I really need your help. this problem destroying the reputation and quality of my company.
thank
Farzad
181355.00 6 [AmountChargeToCreditCard] Say numbers: [525] as Amount - Dollars And Cents
181355.03 6 fn PlaySoundStartNumbers [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\$RV[language]\confirmtransaction.wav],[C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\$RV[language]\\confirmtransaction2.wav],[525],Amount - Dollars And Cents
181355.08 6 rv replace start: [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\$RV[language]\confirmtransaction.wav]
181355.11 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainMenu\}[scriptPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainMenu}[$RV_STARTTIME]{12/22/2004 6:12:48 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[selectLanguage]{1}[Language_Input]{1}[Language]{1}[useCNumO
BuyNew]{1}[scriptEnd_Time]{12/22/2004 6:12:52 PM}[scriptEnd_Goto_Script]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\RefillTransferMoneyPhoneCard\RefillTransferMoneyPhoneCard.vgs}[scriptEnd_Goto_Module]{retrysetCC1}[scrip
Start_Time]{12/22/2004 6:12:52 PM}[scriptStart_CalledFrom_Script]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainMenu\MainMenu.vgs}[scriptStart_CalledFrom_Module]{RefillOrWidraw}[scriptsPath]{C
\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\RefillTransferMoneyPhoneCard\}[scriptPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\RefillTransferMoneyPhoneCard}[retrysetCC1]{1}[retrysetCC1_Input]{0}[retryse
CC1]{0}[retrycount]{0}[GetCNum]{539633}[GetCNum_PathTaken]{success}[lookForCNum_
owCount]{1}[lookForCNum_1_1]{539633}[lookforCNumResult_Input]{539633}[lookforCNu
Result]{539633}[confirmCNum_Input]{539633 = 539633}[confirmCNum]{True}[retrysetPW_Input]{0}[retrysetPW]{0}[retrycount]{0}[Ge
PW]{4000}[GetPW_PathTaken]{success}[lookForPW_RowCount]{1}[lookForPW_1_1]{4000}[
ookforPWResult_Input]{4000}[lookforPWResult]{4000}[cofirmPW_Input]{4000 = 4000}[cofirmPW]{True}[lookForCCNum_RowCount]{1}[lookForCCNum_1_1]{41111111111111
1}[lookForCCNumResult_Input]{"4111111111111111"=""}[lookForCCNumResult]{False}[GetCC_Input]{"False"}[GetCC]{False}[lookForExp_RowCount]{1}[lookForExp_1_1]{0505}[GetExp_Input]
"0505"}[GetExp]{0505}[setGetExp_Input]{"0505"}[setGetExp]{0505}[GetExp]{0505}[checkExpLen_Input]{len("0505") = 4}[checkExpLen]{True}[check Exp]{}[GetAmt]{500}[GetAmt_PathTaken]{success}[checkAmtLen_Input]{500>=100}[checkAmtLen]{True}[checkAmtSize1_Input]{500 <= 2000}[checkAmtSize1]{True}[LanguageEvalu_Input]{1}[LanguageEvalu]{1}[ConfirmOrde
]{1}[CalServiceFee_Input]{((500 * 3) /100)+10}[CalServiceFee]{25}[ResultServiceFee_Input]{25}[ResultServiceFee]{25}[Ad
SerFee&GetAmt_Input]{500 + 25}[AddSerFee&GetAmt]{525}[AddSerFee&GetAmtResult_Input]{525}[AddSerFee&GetAmtResult]{525}[LanguageEvalu_198_Input]{1}[LanguageEvalu_198]{1}[service
ee]{1}[LookForBalance_RowCount]{1}[LookForBalance_1_1]{0}[LookForBalanceResult_I
put]{0}[LookForBalanceResult]{0}[CalculatBalance_Input]{0 + 500}[CalculatBalance]{500}[NewBalance_Input]{500}[NewBalance]{500}[receipt]{2004
222185013}[insertData_RowCount]{1}[updateBalance_RowCount]{1}[GetServiceFee_RowC
unt]{1}[GetServiceFee_1_1]{70}[GetServiceFeeResult_Input]{70}[GetServiceFeeResul
]{70}[CalcuServiceFee_Input]{70+25}[CalcuServiceFee]{95}[TotalServiceFee_Input]{
5}[TotalServiceFee]{95}[updateServiceFee_RowCount]{1}[EvaluateLanguage2_Input]{1
[EvaluateLanguage2]{1}
181355.13 6 rv replace end: [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\confirmtransaction.wav]
181355.22 6 rv replace start: [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\$RV[language]\\confirmtransaction2.wav]
181355.25 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainMenu\}[scriptPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainMenu}[$RV_STARTTIME]{12/22/2004 6:12:48 PM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[selectLanguage]{1}[Language_Input]{1}[Language]{1}[useCNumO
181355.28 6 rv replace end: [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\\confirmtransaction2.wav]
181355.31 6 sVbsFunctionToUse=AmountDollarsAndCents
181355.41 6 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_6_SayNumber.vbs)
181355.53 6 cl Play_Start C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\confirmtransaction.wav,5.wav,hundred.wav,20.wav,5.wav,dollars.wav,and.wav,0
wav,cents.wav,C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\\confirmtransaction2.wav
181355.58 6 play set playid=508328
181355.72 6 PlaySoundStart ok [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\confirmtransaction.wav,C:\Program Files\VoiceGuide\system\voice\5.wav,C:\Program Files\VoiceGuide\system\voice\hundred.wav,C:\Program Files\VoiceGuide\system\voice\20.wav,C:\Program Files\VoiceGuide\system\voice\5.wav,C:\Program Files\VoiceGuide\system\voice\dollars.wav,C:\Program Files\VoiceGuide\system\voice\and.wav,C:\Program Files\VoiceGuide\system\voice\0.wav,C:\Program Files\VoiceGuide\system\voice\cents.wav,C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\\confirmtransaction2.wav]
181355.75 6 timer clear
181355.80 6 wa(10482,50832809)
181355.83 6 callinfo MONITORMODES
181358.75 6 callstate DISCONNECTED 65754 0 0
181358.78 6 ScriptEventCode 9250 iLineState=1600
181358.81 6 LsSayNbrPlay EV_REMOTEPARTY_DISCONNECT
181358.86 6 rv add [Hangup Time]{12/22/2004 6:13:58 PM}
181358.89 6 Hanging up call...
181358.92 6 RecSoundStop ok
181359.02 6 PlaySoundStop err=0
181359.05 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
181359.09 6 fnHangupCall end
181359.14 6 linedevstate 2048 0 0
181359.17 6 callstate IDLE 65754 0 0
181359.20 6 WorkingMode@Idle=
181359.23 6 timer clear
181359.28 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181359.31 6 tapi Reply (LineEvReply) ok 66071 0
181400.33 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
181400.34 6 ScriptEventCode 9008 iLineState=900
181400.39 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
181400.42 6 ReinitTelephony due to IDLE
181400.47 6 tapic lineDeallocateCall(MainCall:65754) 0
181400.81 6 lineOpen(6)=>
181400.86 6 Waiting for a call...
181400.89 6 LineHandle=65601
181400.92 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181401.14 0 dial start any summary:|6:rdy=0|7:idx=0|
181402.17 0 dial start any summary:|6:rdy=0|7:idx=0|
181403.20 0 dial start any summary:|6:rdy=0|7:idx=0|
181404.23 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181404.25 6 ScriptEventCode 9013 iLineState=900
Trace shows disconnect is made as the Dialogic card informs VoiceGuide that it has
heard the disconnect tone.
What are your current settings for these tomes? Please post some
screenshots of your current settings as well as the recording of the disconnect tone played when caller hangs up.
