Guest Hal Netkin Report post Posted 05/06/2003 10:50 PM RE: v.4.9.0 I loaded the Telephone Numbers Loader with about 20 numbers and clicked "Start Dialing." After about five successful outbound calls, I decided to abort the entire operation. There seemed like there was nothing I could do to stop the out-of-control dialer. How do I stop or erase all numbers ed to dial. which were qued to dial? Hal Netkin Share this post Link to post
SupportTeam Report post Posted 05/07/2003 06:32 AM After stopping the VoiceGuide program go to the Telephone Number Loader, select the Script Params tab and press the Delete DialList DB button. This will delete the entire database of the numbers which are queued to be called. You can also open the DialList.mdb file in MS Access if you want to individually delete particular calls. Share this post Link to post
