Guest Tom Report post Posted 12/31/2004 05:42 PM I have tried to download ver 5.1.1 from Intel but once downloaded it say I have a bad archive, so I downloaded ver 5.0.1 I have included a print out of the event trace file: 123928.44 0 sys cleanup Start 123928.46 0 sys cleanup End 124111.16 10 linedevstate 2048 0 0 124111.16 10 callstate OFFERING 66459 0 4 124111.18 10 Answer the call at 12/31/2004 12:41:11 PM 124111.19 10 lineAnswer(66459) => 66442 124111.20 10 callinfo CALLEDID 124111.20 10 callinfo ORIGIN 124111.21 10 ring 0 124111.73 10 callstate CONNECTED 66459 1 0 124111.75 10 callstate CONNECTED 66459,1,0 124111.75 10 WorkingModeTAPI@Connected= 124111.76 10 WorkingModeScript@Connected= 124111.82 10 Inband detection not enabled 124111.82 10 StartLoadedVgs at 12/31/2004 12:41:11 PM 124111.83 10 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\} 124111.84 10 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant} 124111.85 10 rv add [$RV_STARTTIME]{12/31/2004 12:41:11 PM} 124111.87 10 rv add [$RV_DEVICEID]{10} 124111.88 10 rv add [$RV_CIDNAME]{} 124111.90 10 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 124111.91 10 rv add [$RV_CIDNUMBER]{} 124111.93 10 tapi Reply (LineEvReply) ok 66442 0 124111.95 10 callinfo MONITORMODES 124111.97 10 timer clear 124111.98 10 [Welcome] Number Input 124111.00 10 [Welcome] Playing () 124112.01 10 ScriptEventCode 8001 iLineState=1300 124112.02 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 124112.06 10 timer set 2 EV_TIMEOUT_REPLAYMSG 124113.97 10 timer fired EV_TIMEOUT_REPLAYMSG 124113.98 10 ScriptEventCode 9005 iLineState=1301 124114.00 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 124114.02 10 [Welcome] Playing () 124114.03 10 ScriptEventCode 8001 iLineState=1300 124114.04 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 124114.06 10 timer set 2 EV_TIMEOUT_REPLAYMSG 124116.07 10 timer fired EV_TIMEOUT_REPLAYMSG 124116.08 10 ScriptEventCode 9005 iLineState=1301 124116.10 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 124116.11 10 [Welcome] Playing () 124116.13 10 ScriptEventCode 8001 iLineState=1300 124116.14 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 124116.16 10 timer set 2 EV_TIMEOUT_REPLAYMSG 124118.18 10 timer fired EV_TIMEOUT_REPLAYMSG 124118.20 10 ScriptEventCode 9005 iLineState=1301 124118.21 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 124118.21 10 [Welcome] Playing () 124118.23 10 ScriptEventCode 8001 iLineState=1300 124118.25 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 124118.27 10 timer set 2 EV_TIMEOUT_REPLAYMSG 124120.28 10 timer fired EV_TIMEOUT_REPLAYMSG 124120.29 10 ScriptEventCode 9005 iLineState=1301 124120.31 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 124120.32 10 [Welcome] Playing () 124120.34 10 ScriptEventCode 8001 iLineState=1300 124120.35 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 124120.37 10 timer set 2 EV_TIMEOUT_REPLAYMSG 124122.38 10 timer fired EV_TIMEOUT_REPLAYMSG 124122.40 10 ScriptEventCode 9005 iLineState=1301 124122.41 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG 124122.43 10 [Welcome] Playing () 124122.44 10 ScriptEventCode 8001 iLineState=1300 124122.46 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 124122.47 10 timer set 10 EV_TIMEOUT_HANGUP 124122.48 10 timer set 6 EV_TIMEOUT_ENTERDATA 124128.51 10 timer fired EV_TIMEOUT_ENTERDATA 124128.52 10 ScriptEventCode 9006 iLineState=1301 124128.54 10 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 124128.56 10 rv add [Welcome]{} 124128.57 10 AddRVns [Welcome_PathTaken]{fail} 124128.59 10 rv add [Hangup Time]{12/31/2004 12:41:28 PM} 124128.60 10 Hanging up call... [No data entered] 124128.62 10 RecSoundStop ok 124128.64 10 PlaySoundStop err=0 124128.65 10 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 124128.67 10 fnHangupCall end 124128.71 10 linedevstate 2048 0 0 124128.72 10 callstate IDLE 66459 0 0 124128.74 10 WorkingMode@Idle= 124128.76 10 timer clear 124128.88 10 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 124128.89 10 tapi Reply (LineEvReply) ok 65964 0 124129.81 10 timer fired EV_TIMEOUT_TIMETOREINITLINE 124129.82 10 ScriptEventCode 9008 iLineState=900 124129.84 10 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 124129.85 10 ReinitTelephony due to IDLE 124129.88 10 tapic lineDeallocateCall(MainCall:66459) 0 124130.36 10 lineOpen(10)=> 124130.38 10 Waiting for a call... 124130.40 10 LineHandle=65896 124130.41 10 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 124130.98 0 dial start any summary:|10:rdy=0|11:idx=0| 124132.03 0 dial start any summary:|10:rdy=0|11:idx=0| 124133.07 0 dial start any summary:|10:rdy=0|11:idx=0| 124133.45 10 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 124133.47 10 ScriptEventCode 9013 iLineState=900 I have no idea what is wrong here. Also re-installed the TAPI driver. Help!! Share this post Link to post
SupportTeam Report post Posted 01/01/2005 03:57 AM Have a look at the script that you have selected to use. That script does not ship with any sound files - you need to record your own sound file and assign that file to be played in the module [Welcome]. Trace shows that no sound file is specified in that module right now: 124111.00 10 [Welcome] Playing () Share this post Link to post
Guest tefernan Report post Posted 01/01/2005 08:15 PM You are correct, I recorded a script and also have the same issue, here is my log file output: 150934.07 6 linedevstate 2048 0 0 150934.16 6 callstate OFFERING 65911 0 4 150934.19 6 Answer the call at 1/1/2005 3:09:34 PM 150934.23 6 lineAnswer(65911) => 65894 150934.23 6 callinfo CALLEDID 150934.23 6 callinfo ORIGIN 150934.25 6 ring 0 150934.79 6 callstate CONNECTED 65911 1 0 150934.80 6 callstate CONNECTED 65911,1,0 150934.80 6 WorkingModeTAPI@Connected= 150934.81 6 WorkingModeScript@Connected= 150934.86 6 Inband detection not enabled 150934.89 6 StartLoadedVgs at 1/1/2005 3:09:34 PM 150934.90 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate\} 150934.91 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate} 150934.94 6 rv add [$RV_STARTTIME]{1/1/2005 3:09:34 PM} 150934.95 6 rv add [$RV_DEVICEID]{6} 150934.97 6 rv add [$RV_CIDNAME]{} 150934.98 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 150934.00 6 rv add [$RV_CIDNUMBER]{} 150935.03 6 tapi Reply (LineEvReply) ok 65894 0 150935.05 6 callinfo MONITORMODES 150935.09 6 timer clear 150935.10 6 [Play 1] Playing 150935.14 6 [Play 1] Playing (C:\Broker-Scripts\Free Home Market Value.wav) 150935.16 6 play set playid=763778 150935.53 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Broker-Scripts\Free Home Market Value.wav] 150935.59 6 path {WAVERR_BADFORMAT} not found 150935.61 6 play set playid=763778 150935.79 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav] 150935.81 6 For Dialogic use: PCM 11Khz 8bit Mono 150935.85 6 rv add [Hangup Time]{1/1/2005 3:09:35 PM} 150935.87 6 Hanging up call... [srlib PlaySoundStart] 150935.91 6 RecSoundStop ok 150935.93 6 PlaySoundStop err=0 150935.94 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 150935.97 6 fnHangupCall end 150935.99 6 RunModule PLAY end 150936.01 6 play end current play (playid=0) 150936.03 6 ScriptEventCode 8001 iLineState=900 150936.04 6 LsAwaitingCalls EV_PLAY_FINISHED 150936.06 6 play end current play (playid=0) 150936.08 6 ScriptEventCode 8001 iLineState=900 150936.10 6 LsAwaitingCalls EV_PLAY_FINISHED 150936.85 6 linedevstate 2048 0 0 150936.87 6 callstate IDLE 65911 0 0 150936.89 6 WorkingMode@Idle= 150936.90 6 timer clear 150937.06 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 150937.07 6 tapi Reply (LineEvReply) ok 65877 0 150937.99 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 150938.01 6 ScriptEventCode 9008 iLineState=900 150938.02 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 150938.04 6 ReinitTelephony due to IDLE 150938.08 6 tapic lineDeallocateCall(MainCall:65911) 0 150938.32 6 lineOpen(6)=> 150938.34 6 Waiting for a call... 150938.35 6 LineHandle=65860 150938.37 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 150938.41 0 dial start any summary:|6:rdy=0|7:idx=0| 150939.45 0 dial start any summary:|6:rdy=0|7:idx=0| 150940.48 0 dial start any summary:|6:rdy=0|7:idx=0| 150941.42 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 150941.43 6 ScriptEventCode 9013 iLineState=900 150956.18 0 sys cleanup Start 150956.21 0 sys cleanup End I have since went ahead and purchased your product online, I just need to have the product key sent by sales. Any idieas what may be wrong at this point? Tom Share this post Link to post
SupportTeam Report post Posted 01/02/2005 12:04 AM Trace shows that teh sound file is not ion right format. 150935.14 6 [Play 1] Playing (C:\Broker-Scripts\Free Home Market Value.wav) 150935.16 6 play set playid=763778 150935.53 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Broker-Scripts\Free Home Market Value.wav] Dialogic Wave driver prefers sound files in the following format PCM 11025Hz, 8bit, Mono. When using a Dialogic card, all sound files should be recorded in this format. Share this post Link to post
Guest Tom Report post Posted 01/02/2005 03:34 PM Okay, I recorded a new script after I recieved my Lic. key and used the Dialogic recommended format. Here is my log file: 103153.95 6 linedevstate 2048 0 0 103153.96 6 callstate OFFERING 65996 0 4 103153.96 6 Answer the call at 1/2/2005 10:31:53 AM 103153.99 6 lineAnswer(65996) => 65979 103153.99 6 callinfo CALLEDID 103154.00 6 callinfo ORIGIN 103154.01 6 ring 0 103154.57 6 callstate CONNECTED 65996 1 0 103154.58 6 callstate CONNECTED 65996,1,0 103154.59 6 WorkingModeTAPI@Connected= 103154.60 6 WorkingModeScript@Connected= 103154.65 6 Inband detection not enabled 103154.66 6 StartLoadedVgs at 1/2/2005 10:31:54 AM 103154.67 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\} 103154.68 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate} 103154.69 6 rv add [$RV_STARTTIME]{1/2/2005 10:31:54 AM} 103154.70 6 rv add [$RV_DEVICEID]{6} 103154.71 6 rv add [$RV_CIDNAME]{} 103154.72 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 103154.74 6 rv add [$RV_CIDNUMBER]{} 103154.75 6 tapi Reply (LineEvReply) ok 65979 0 103154.77 6 callinfo MONITORMODES 103154.78 6 timer clear 103154.81 6 [Play 1] Playing 103154.83 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav) 103154.85 6 play set playid=898471 103154.90 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav] 103154.92 6 path {WAVERR_BADFORMAT} not found 103154.95 6 play set playid=898471 103155.01 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav] 103155.04 6 For Dialogic use: PCM 11Khz 8bit Mono 103155.06 6 rv add [Hangup Time]{1/2/2005 10:31:55 AM} 103155.09 6 Hanging up call... [srlib PlaySoundStart] 103155.12 6 RecSoundStop ok 103155.14 6 PlaySoundStop err=0 103155.17 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 103155.20 6 fnHangupCall end 103155.22 6 RunModule PLAY end 103155.25 6 play end current play (playid=0) 103155.27 6 ScriptEventCode 8001 iLineState=900 103155.30 6 LsAwaitingCalls EV_PLAY_FINISHED 103155.32 6 play end current play (playid=0) 103155.35 6 ScriptEventCode 8001 iLineState=900 103155.37 6 LsAwaitingCalls EV_PLAY_FINISHED 103156.66 6 linedevstate 2048 0 0 103156.70 6 callstate IDLE 65996 0 0 103156.71 6 WorkingMode@Idle= 103156.74 6 timer clear 103156.86 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 103156.89 6 tapi Reply (LineEvReply) ok 65962 0 103157.80 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 103157.82 6 ScriptEventCode 9008 iLineState=900 103157.85 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 103157.87 6 ReinitTelephony due to IDLE 103157.89 6 tapic lineDeallocateCall(MainCall:65996) 0 103158.14 6 lineOpen(6)=> 103158.16 6 Waiting for a call... 103158.19 6 LineHandle=65945 103158.21 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 103158.41 0 dial start any summary:|6:rdy=0| 103159.43 0 dial start any summary:|6:rdy=0| 103200.45 0 dial start any summary:|6:rdy=0| 103201.23 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 103201.25 6 ScriptEventCode 9013 iLineState=900 I hope this helps again. Tom Share this post Link to post
SupportTeam Report post Posted 01/02/2005 11:17 PM Could you please .ZIP up and post the Market Value.wav sound file that you are using. I'd probably just re-install the Dialogic wave drivers as well. Share this post Link to post
Guest Tom Report post Posted 01/03/2005 09:03 PM I will zip the file to you when I'm back in the office, I also removed both the wave drivers and the Dialogic driver 5.0.1 and have installed version 5.1.1, rebooted and installed the wave driver and also left the configuration set for "default" on the dialogic card settings under "Modem",,."Advance" Drivers loaded with no problems. The time zone difference is hard to work with, but I appreciate all your efforts. Share this post Link to post
Guest tefernan Report post Posted 01/04/2005 01:10 AM I ran event trace at office, here are the results: 200552.28 0 sys cleanup Start 200552.38 0 sys cleanup End 200559.63 6 linedevstate 2048 0 0 200559.66 6 callstate OFFERING 66048 0 4 200559.66 6 Answer the call at 1/3/2005 8:05:59 PM 200559.71 6 lineAnswer(66048) => 66047 200559.73 6 callinfo CALLEDID 200559.74 6 callinfo ORIGIN 200559.76 6 ring 0 200600.26 6 callstate CONNECTED 66048 1 0 200600.27 6 callstate CONNECTED 66048,1,0 200600.27 6 WorkingModeTAPI@Connected= 200600.28 6 WorkingModeScript@Connected= 200600.34 6 Inband detection not enabled 200600.37 6 StartLoadedVgs at 1/3/2005 8:06:00 PM 200600.38 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\} 200600.38 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate} 200600.41 6 rv add [$RV_STARTTIME]{1/3/2005 8:06:00 PM} 200600.42 6 rv add [$RV_DEVICEID]{6} 200600.45 6 rv add [$RV_CIDNAME]{} 200600.45 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 200600.47 6 rv add [$RV_CIDNUMBER]{} 200600.51 6 tapi Reply (LineEvReply) ok 66047 0 200600.52 6 callinfo MONITORMODES 200600.53 6 timer clear 200600.55 6 [Play 1] Playing 200600.59 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav) 200600.59 6 play set playid=5225 200601.61 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav] 200601.66 6 path {WAVERR_BADFORMAT} not found 200601.69 6 play set playid=5225 200601.83 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav] 200601.86 6 For Dialogic use: PCM 11Khz 8bit Mono 200601.91 6 rv add [Hangup Time]{1/3/2005 8:06:01 PM} 200601.94 6 Hanging up call... [srlib PlaySoundStart] 200601.98 6 RecSoundStop ok 200602.01 6 PlaySoundStop err=0 200602.04 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 200602.07 6 fnHangupCall end 200602.10 6 RunModule PLAY end 200602.13 6 play end current play (playid=0) 200602.15 6 ScriptEventCode 8001 iLineState=900 200602.18 6 LsAwaitingCalls EV_PLAY_FINISHED 200602.21 6 play end current play (playid=0) 200602.23 6 ScriptEventCode 8001 iLineState=900 200602.26 6 LsAwaitingCalls EV_PLAY_FINISHED 200602.30 6 linedevstate 2048 0 0 200602.33 6 callstate IDLE 66048 0 0 200602.36 6 WorkingMode@Idle= 200602.38 6 timer clear 200602.58 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 200602.60 6 tapi Reply (LineEvReply) ok 66030 0 200603.53 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 200603.55 6 ScriptEventCode 9008 iLineState=900 200603.58 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 200603.61 6 ReinitTelephony due to IDLE 200603.65 6 tapic lineDeallocateCall(MainCall:66048) 0 200603.91 6 lineOpen(6)=> 200603.94 6 Waiting for a call... 200603.96 6 LineHandle=66013 200603.99 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 200604.64 0 dial start any summary:|6:rdy=0| 200605.67 0 dial start any summary:|6:rdy=0| 200606.70 0 dial start any summary:|6:rdy=0| 200607.03 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 200607.06 6 ScriptEventCode 9013 iLineState=900 Market_Value.vgs Share this post Link to post
SupportTeam Report post Posted 01/04/2005 01:12 AM Could you please .ZIP up and post the Market Value.wav sound file that you are using. Share this post Link to post
Guest tefernan Report post Posted 01/04/2005 01:36 AM Here is another file format Market_Value.zip Share this post Link to post
Guest Tom Report post Posted 01/05/2005 10:48 PM Have you checked the file? I did not have any problems playing the file thru my speakers. Share this post Link to post
Guest Tom Report post Posted 01/05/2005 11:28 PM Let me make another note,. VG seems to pickup and run the script till the end and then hang up. Share this post Link to post
SupportTeam Report post Posted 01/05/2005 11:50 PM The file looks OK, so the problem seems to be with the Wave drivers. Can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony card only. To remove other wave drivers got to Control Panel, double clock on System, select the Device Manager tab and go to Sound/Video/Game Controllers entry - then delete all other wave drivers. You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager. VG seems to pickup and run the script till the end and then hang up. Could you please post a copy of VoiceGuide's Debug Printout which captures this. Share this post Link to post
Guest tefernan Report post Posted 01/07/2005 12:39 PM I removed the wave drivers for dialogic card and uninstalled the sound card and disable it also. I then re-installed the wave driver and rebooted system. I was able to run the dialogic "Horoscope" application with no problems, I tried to run VG afterwards and I have the same issue, I recorded the log file: 073357.16 0 sys cleanup Start 073357.33 0 sys cleanup End 073404.64 6 linedevstate 2048 0 0 073404.64 6 callstate OFFERING 66048 0 4 073404.65 6 Answer the call at 1/7/2005 7:34:04 AM 073404.67 6 lineAnswer(66048) => 66047 073404.68 6 callinfo CALLEDID 073404.68 6 callinfo ORIGIN 073404.69 6 ring 0 073405.23 6 callstate CONNECTED 66048 1 0 073405.24 6 callstate CONNECTED 66048,1,0 073405.24 6 WorkingModeTAPI@Connected= 073405.25 6 WorkingModeScript@Connected= 073405.30 6 Inband detection not enabled 073405.33 6 StartLoadedVgs at 1/7/2005 7:34:05 AM 073405.33 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\} 073405.34 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate} 073405.37 6 rv add [$RV_STARTTIME]{1/7/2005 7:34:05 AM} 073405.38 6 rv add [$RV_DEVICEID]{6} 073405.39 6 rv add [$RV_CIDNAME]{} 073405.40 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 073405.41 6 rv add [$RV_CIDNUMBER]{} 073405.43 6 tapi Reply (LineEvReply) ok 66047 0 073405.44 6 callinfo MONITORMODES 073405.45 6 timer clear 073405.46 6 [Play 1] Playing 073405.49 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav) 073405.51 6 play set playid=314131 073406.00 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav] 073406.03 6 path {WAVERR_BADFORMAT} not found 073406.05 6 play set playid=314131 073406.20 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav] 073406.23 6 For Dialogic use: PCM 11Khz 8bit Mono 073406.28 6 rv add [Hangup Time]{1/7/2005 7:34:06 AM} 073406.31 6 Hanging up call... [srlib PlaySoundStart] 073406.36 6 RecSoundStop ok 073406.39 6 PlaySoundStop err=0 073406.41 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 073406.47 6 fnHangupCall end 073406.49 6 RunModule PLAY end 073406.53 6 play end current play (playid=0) 073406.55 6 ScriptEventCode 8001 iLineState=900 073406.58 6 LsAwaitingCalls EV_PLAY_FINISHED 073406.61 6 play end current play (playid=0) 073406.64 6 ScriptEventCode 8001 iLineState=900 073406.66 6 LsAwaitingCalls EV_PLAY_FINISHED 073407.24 6 linedevstate 2048 0 0 073407.27 6 callstate IDLE 66048 0 0 073407.30 6 WorkingMode@Idle= 073407.32 6 timer clear 073407.51 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 073407.54 6 tapi Reply (LineEvReply) ok 66030 0 073408.51 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 073408.54 6 ScriptEventCode 9008 iLineState=900 073408.55 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 073408.59 6 ReinitTelephony due to IDLE 073408.62 6 tapic lineDeallocateCall(MainCall:66048) 0 073408.87 6 lineOpen(6)=> 073408.90 6 Waiting for a call... 073408.93 6 LineHandle=66013 073408.96 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 073408.99 0 dial start any summary:|6:rdy=0| 073410.01 0 dial start any summary:|6:rdy=0| 073411.04 0 dial start any summary:|6:rdy=0| 073411.98 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 073412.00 6 ScriptEventCode 9013 iLineState=900 Any clues here of the problem? Share this post Link to post
Guest tefernan Report post Posted 01/07/2005 01:03 PM Is there a way you can connect to my system and check this? I realize the time zone differance since I'm in the USA but, I can come in anytime to make this work even leave the system online while you check. I need to move past this problem and on to bigger issues in planning the layout of this whole thing and cant move past this... what would seem like a simple problem (but we know better in the real world) of just pickup and start playing the recorded message. Share this post Link to post
Guest Tom Report post Posted 01/08/2005 01:41 AM Well I reformated the system, removed the sound card. The installed Windows 2000 with SP4, performed a windows update..rebooted. 1. Installed Intel 5.1.1 driver, rebooted..ran DCM with no problems..used Horoscope.exe to test the driver,..ran with no problems. 2. installed MDAC 2.8 3. Installed wave driver..rebooted 4. installed VG,..no issues on install 5. used the same file I sent you to test with and came up with the same problem or so it seems, picks up and you hear nothing on the phone, then hangs up. Here is the log file: 203329.42 6 linedevstate 2048 0 0 203329.43 6 callstate OFFERING 66099 0 4 203329.46 6 Answer the call at 1/7/2005 8:33:29 PM 203329.47 6 lineAnswer(66099) => 66082 203329.47 6 callinfo CALLEDID 203329.47 6 callinfo ORIGIN 203329.47 6 ring 0 203330.01 6 callstate CONNECTED 66099 1 0 203330.01 6 callstate CONNECTED 66099,1,0 203330.01 6 WorkingModeTAPI@Connected= 203330.01 6 WorkingModeScript@Connected= 203330.07 6 Inband detection not enabled 203330.09 6 StartLoadedVgs at 1/7/2005 8:33:30 PM 203330.09 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\} 203330.09 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate} 203330.09 6 rv add [$RV_STARTTIME]{1/7/2005 8:33:30 PM} 203330.10 6 rv add [$RV_DEVICEID]{6} 203330.10 6 rv add [$RV_CIDNAME]{} 203330.10 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 203330.10 6 rv add [$RV_CIDNUMBER]{} 203330.11 6 tapi Reply (LineEvReply) ok 66082 0 203330.12 6 callinfo MONITORMODES 203330.12 6 timer clear 203330.12 6 [Play 1] Playing 203330.15 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav) 203330.15 6 play set playid=173940 203330.17 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav] 203330.18 6 play set playid=173940 203330.79 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav] 203330.80 6 For Dialogic use: PCM 11Khz 8bit Mono 203330.82 6 rv add [Hangup Time]{1/7/2005 8:33:30 PM} 203330.83 6 Hanging up call... [srlib PlaySoundStart] 203330.83 6 RecSoundStop ok 203330.84 6 PlaySoundStop err=0 203330.84 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 203330.85 6 fnHangupCall end 203330.86 6 RunModule PLAY end 203330.86 6 play end current play (playid=0) 203330.87 6 ScriptEventCode 8001 iLineState=900 203330.87 6 LsAwaitingCalls EV_PLAY_FINISHED 203330.88 6 play end current play (playid=0) 203330.89 6 ScriptEventCode 8001 iLineState=900 203330.89 6 LsAwaitingCalls EV_PLAY_FINISHED 203332.05 6 linedevstate 2048 0 0 203332.05 6 callstate IDLE 66099 0 0 203332.06 6 WorkingMode@Idle= 203332.06 6 timer clear 203332.09 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 203332.10 6 tapi Reply (LineEvReply) ok 66065 0 203333.02 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 203333.02 6 ScriptEventCode 9008 iLineState=900 203333.02 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 203333.02 6 ReinitTelephony due to IDLE 203333.05 6 tapic lineDeallocateCall(MainCall:66099) 0 203333.27 6 lineOpen(6)=> 203333.27 6 Waiting for a call... 203333.27 6 LineHandle=66048 203333.28 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 203333.91 0 dial start any summary:|6:rdy=0| 203334.91 0 dial start any summary:|6:rdy=0| 203335.91 0 dial start any summary:|6:rdy=0| 203336.29 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 203336.29 6 ScriptEventCode 9013 iLineState=900 203349.43 0 sys cleanup Start 203349.43 0 sys cleanup End I hope this helps. Share this post Link to post
SupportTeam Report post Posted 01/08/2005 10:57 PM Does the Calling Card demo script work for you in v5.2.3 ? Share this post Link to post
Guest Tom Report post Posted 01/09/2005 01:37 PM THe credit card demo script does not work for me also, the same problem happens. Dialogic card answers the call and then hangs up. Share this post Link to post
