Vg Hangs Up After A Second Before Your Hear Anythi
I have tried to download ver 5.1.1 from Intel but once downloaded it say I have a bad archive, so I downloaded ver 5.0.1
I have included a print out of the event trace file:
123928.44 0 sys cleanup Start
123928.46 0 sys cleanup End
124111.16 10 linedevstate 2048 0 0
124111.16 10 callstate OFFERING 66459 0 4
124111.18 10 Answer the call at 12/31/2004 12:41:11 PM
124111.19 10 lineAnswer(66459) => 66442
124111.20 10 callinfo CALLEDID
124111.20 10 callinfo ORIGIN
124111.21 10 ring 0
124111.73 10 callstate CONNECTED 66459 1 0
124111.75 10 callstate CONNECTED 66459,1,0
124111.75 10 WorkingModeTAPI@Connected=
124111.76 10 WorkingModeScript@Connected=
124111.82 10 Inband detection not enabled
124111.82 10 StartLoadedVgs at 12/31/2004 12:41:11 PM
124111.83 10 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\}
124111.84 10 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant}
124111.85 10 rv add [$RV_STARTTIME]{12/31/2004 12:41:11 PM}
124111.87 10 rv add [$RV_DEVICEID]{10}
124111.88 10 rv add [$RV_CIDNAME]{}
124111.90 10 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
124111.91 10 rv add [$RV_CIDNUMBER]{}
124111.93 10 tapi Reply (LineEvReply) ok 66442 0
124111.95 10 callinfo MONITORMODES
124111.97 10 timer clear
124111.98 10 [Welcome] Number Input
124111.00 10 [Welcome] Playing ()
124112.01 10 ScriptEventCode 8001 iLineState=1300
124112.02 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
124112.06 10 timer set 2 EV_TIMEOUT_REPLAYMSG
124113.97 10 timer fired EV_TIMEOUT_REPLAYMSG
124113.98 10 ScriptEventCode 9005 iLineState=1301
124114.00 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
124114.02 10 [Welcome] Playing ()
124114.03 10 ScriptEventCode 8001 iLineState=1300
124114.04 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
124114.06 10 timer set 2 EV_TIMEOUT_REPLAYMSG
124116.07 10 timer fired EV_TIMEOUT_REPLAYMSG
124116.08 10 ScriptEventCode 9005 iLineState=1301
124116.10 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
124116.11 10 [Welcome] Playing ()
124116.13 10 ScriptEventCode 8001 iLineState=1300
124116.14 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
124116.16 10 timer set 2 EV_TIMEOUT_REPLAYMSG
124118.18 10 timer fired EV_TIMEOUT_REPLAYMSG
124118.20 10 ScriptEventCode 9005 iLineState=1301
124118.21 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
124118.21 10 [Welcome] Playing ()
124118.23 10 ScriptEventCode 8001 iLineState=1300
124118.25 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
124118.27 10 timer set 2 EV_TIMEOUT_REPLAYMSG
124120.28 10 timer fired EV_TIMEOUT_REPLAYMSG
124120.29 10 ScriptEventCode 9005 iLineState=1301
124120.31 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
124120.32 10 [Welcome] Playing ()
124120.34 10 ScriptEventCode 8001 iLineState=1300
124120.35 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
124120.37 10 timer set 2 EV_TIMEOUT_REPLAYMSG
124122.38 10 timer fired EV_TIMEOUT_REPLAYMSG
124122.40 10 ScriptEventCode 9005 iLineState=1301
124122.41 10 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
124122.43 10 [Welcome] Playing ()
124122.44 10 ScriptEventCode 8001 iLineState=1300
124122.46 10 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
124122.47 10 timer set 10 EV_TIMEOUT_HANGUP
124122.48 10 timer set 6 EV_TIMEOUT_ENTERDATA
124128.51 10 timer fired EV_TIMEOUT_ENTERDATA
124128.52 10 ScriptEventCode 9006 iLineState=1301
124128.54 10 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
124128.56 10 rv add [Welcome]{}
124128.57 10 AddRVns [Welcome_PathTaken]{fail}
124128.59 10 rv add [Hangup Time]{12/31/2004 12:41:28 PM}
124128.60 10 Hanging up call... [No data entered]
124128.62 10 RecSoundStop ok
124128.64 10 PlaySoundStop err=0
124128.65 10 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
124128.67 10 fnHangupCall end
124128.71 10 linedevstate 2048 0 0
124128.72 10 callstate IDLE 66459 0 0
124128.74 10 WorkingMode@Idle=
124128.76 10 timer clear
124128.88 10 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
124128.89 10 tapi Reply (LineEvReply) ok 65964 0
124129.81 10 timer fired EV_TIMEOUT_TIMETOREINITLINE
124129.82 10 ScriptEventCode 9008 iLineState=900
124129.84 10 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
124129.85 10 ReinitTelephony due to IDLE
124129.88 10 tapic lineDeallocateCall(MainCall:66459) 0
124130.36 10 lineOpen(10)=>
124130.38 10 Waiting for a call...
124130.40 10 LineHandle=65896
124130.41 10 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
124130.98 0 dial start any summary:|10:rdy=0|11:idx=0|
124132.03 0 dial start any summary:|10:rdy=0|11:idx=0|
124133.07 0 dial start any summary:|10:rdy=0|11:idx=0|
124133.45 10 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
124133.47 10 ScriptEventCode 9013 iLineState=900
I have no idea what is wrong here.
Also re-installed the TAPI driver.
Help!!
Have a look at the script that you have selected to use.
That script does not ship with any sound files - you need to record your own sound file and assign that file to be played in the module [Welcome].
Trace shows that no sound file is specified in that module right now:
You are correct,
I recorded a script and also have the same issue, here is my log file output:
150934.07 6 linedevstate 2048 0 0
150934.16 6 callstate OFFERING 65911 0 4
150934.19 6 Answer the call at 1/1/2005 3:09:34 PM
150934.23 6 lineAnswer(65911) => 65894
150934.23 6 callinfo CALLEDID
150934.23 6 callinfo ORIGIN
150934.25 6 ring 0
150934.79 6 callstate CONNECTED 65911 1 0
150934.80 6 callstate CONNECTED 65911,1,0
150934.80 6 WorkingModeTAPI@Connected=
150934.81 6 WorkingModeScript@Connected=
150934.86 6 Inband detection not enabled
150934.89 6 StartLoadedVgs at 1/1/2005 3:09:34 PM
150934.90 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate\}
150934.91 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate}
150934.94 6 rv add [$RV_STARTTIME]{1/1/2005 3:09:34 PM}
150934.95 6 rv add [$RV_DEVICEID]{6}
150934.97 6 rv add [$RV_CIDNAME]{}
150934.98 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
150934.00 6 rv add [$RV_CIDNUMBER]{}
150935.03 6 tapi Reply (LineEvReply) ok 65894 0
150935.05 6 callinfo MONITORMODES
150935.09 6 timer clear
150935.10 6 [Play 1] Playing
150935.14 6 [Play 1] Playing (C:\Broker-Scripts\Free Home Market Value.wav)
150935.16 6 play set playid=763778
150935.53 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Broker-Scripts\Free Home Market Value.wav]
150935.59 6 path {WAVERR_BADFORMAT} not found
150935.61 6 play set playid=763778
150935.79 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
150935.81 6 For Dialogic use: PCM 11Khz 8bit Mono
150935.85 6 rv add [Hangup Time]{1/1/2005 3:09:35 PM}
150935.87 6 Hanging up call... [srlib PlaySoundStart]
150935.91 6 RecSoundStop ok
150935.93 6 PlaySoundStop err=0
150935.94 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
150935.97 6 fnHangupCall end
150935.99 6 RunModule PLAY end
150936.01 6 play end current play (playid=0)
150936.03 6 ScriptEventCode 8001 iLineState=900
150936.04 6 LsAwaitingCalls EV_PLAY_FINISHED
150936.06 6 play end current play (playid=0)
150936.08 6 ScriptEventCode 8001 iLineState=900
150936.10 6 LsAwaitingCalls EV_PLAY_FINISHED
150936.85 6 linedevstate 2048 0 0
150936.87 6 callstate IDLE 65911 0 0
150936.89 6 WorkingMode@Idle=
150936.90 6 timer clear
150937.06 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
150937.07 6 tapi Reply (LineEvReply) ok 65877 0
150937.99 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
150938.01 6 ScriptEventCode 9008 iLineState=900
150938.02 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
150938.04 6 ReinitTelephony due to IDLE
150938.08 6 tapic lineDeallocateCall(MainCall:65911) 0
150938.32 6 lineOpen(6)=>
150938.34 6 Waiting for a call...
150938.35 6 LineHandle=65860
150938.37 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
150938.41 0 dial start any summary:|6:rdy=0|7:idx=0|
150939.45 0 dial start any summary:|6:rdy=0|7:idx=0|
150940.48 0 dial start any summary:|6:rdy=0|7:idx=0|
150941.42 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
150941.43 6 ScriptEventCode 9013 iLineState=900
150956.18 0 sys cleanup Start
150956.21 0 sys cleanup End
I have since went ahead and purchased your product online, I just need to have the product key sent by sales.
Any idieas what may be wrong at this point?
Tom
Trace shows that teh sound file is not ion right format.
Dialogic Wave driver prefers sound files in the following format PCM 11025Hz, 8bit, Mono. When using a Dialogic card, all sound files should be recorded in this format.
Okay, I recorded a new script after I recieved my Lic. key and used the Dialogic recommended format.
Here is my log file:
103153.95 6 linedevstate 2048 0 0
103153.96 6 callstate OFFERING 65996 0 4
103153.96 6 Answer the call at 1/2/2005 10:31:53 AM
103153.99 6 lineAnswer(65996) => 65979
103153.99 6 callinfo CALLEDID
103154.00 6 callinfo ORIGIN
103154.01 6 ring 0
103154.57 6 callstate CONNECTED 65996 1 0
103154.58 6 callstate CONNECTED 65996,1,0
103154.59 6 WorkingModeTAPI@Connected=
103154.60 6 WorkingModeScript@Connected=
103154.65 6 Inband detection not enabled
103154.66 6 StartLoadedVgs at 1/2/2005 10:31:54 AM
103154.67 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\}
103154.68 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate}
103154.69 6 rv add [$RV_STARTTIME]{1/2/2005 10:31:54 AM}
103154.70 6 rv add [$RV_DEVICEID]{6}
103154.71 6 rv add [$RV_CIDNAME]{}
103154.72 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
103154.74 6 rv add [$RV_CIDNUMBER]{}
103154.75 6 tapi Reply (LineEvReply) ok 65979 0
103154.77 6 callinfo MONITORMODES
103154.78 6 timer clear
103154.81 6 [Play 1] Playing
103154.83 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav)
103154.85 6 play set playid=898471
103154.90 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav]
103154.92 6 path {WAVERR_BADFORMAT} not found
103154.95 6 play set playid=898471
103155.01 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
103155.04 6 For Dialogic use: PCM 11Khz 8bit Mono
103155.06 6 rv add [Hangup Time]{1/2/2005 10:31:55 AM}
103155.09 6 Hanging up call... [srlib PlaySoundStart]
103155.12 6 RecSoundStop ok
103155.14 6 PlaySoundStop err=0
103155.17 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
103155.20 6 fnHangupCall end
103155.22 6 RunModule PLAY end
103155.25 6 play end current play (playid=0)
103155.27 6 ScriptEventCode 8001 iLineState=900
103155.30 6 LsAwaitingCalls EV_PLAY_FINISHED
103155.32 6 play end current play (playid=0)
103155.35 6 ScriptEventCode 8001 iLineState=900
103155.37 6 LsAwaitingCalls EV_PLAY_FINISHED
103156.66 6 linedevstate 2048 0 0
103156.70 6 callstate IDLE 65996 0 0
103156.71 6 WorkingMode@Idle=
103156.74 6 timer clear
103156.86 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
103156.89 6 tapi Reply (LineEvReply) ok 65962 0
103157.80 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
103157.82 6 ScriptEventCode 9008 iLineState=900
103157.85 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
103157.87 6 ReinitTelephony due to IDLE
103157.89 6 tapic lineDeallocateCall(MainCall:65996) 0
103158.14 6 lineOpen(6)=>
103158.16 6 Waiting for a call...
103158.19 6 LineHandle=65945
103158.21 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
103158.41 0 dial start any summary:|6:rdy=0|
103159.43 0 dial start any summary:|6:rdy=0|
103200.45 0 dial start any summary:|6:rdy=0|
103201.23 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
103201.25 6 ScriptEventCode 9013 iLineState=900
I hope this helps again.
Tom
Could you please .ZIP up and post the Market Value.wav sound file that you are using.
I'd probably just re-install the Dialogic wave drivers as well.
I will zip the file to you when I'm back in the office, I also removed both the wave drivers and the Dialogic driver 5.0.1 and have installed version 5.1.1, rebooted and installed the wave driver and also left the configuration set for "default" on the dialogic card settings under "Modem",,."Advance"
Drivers loaded with no problems.
The time zone difference is hard to work with, but I appreciate all your efforts.
I ran event trace at office, here are the results:
200552.28 0 sys cleanup Start
200552.38 0 sys cleanup End
200559.63 6 linedevstate 2048 0 0
200559.66 6 callstate OFFERING 66048 0 4
200559.66 6 Answer the call at 1/3/2005 8:05:59 PM
200559.71 6 lineAnswer(66048) => 66047
200559.73 6 callinfo CALLEDID
200559.74 6 callinfo ORIGIN
200559.76 6 ring 0
200600.26 6 callstate CONNECTED 66048 1 0
200600.27 6 callstate CONNECTED 66048,1,0
200600.27 6 WorkingModeTAPI@Connected=
200600.28 6 WorkingModeScript@Connected=
200600.34 6 Inband detection not enabled
200600.37 6 StartLoadedVgs at 1/3/2005 8:06:00 PM
200600.38 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\}
200600.38 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate}
200600.41 6 rv add [$RV_STARTTIME]{1/3/2005 8:06:00 PM}
200600.42 6 rv add [$RV_DEVICEID]{6}
200600.45 6 rv add [$RV_CIDNAME]{}
200600.45 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
200600.47 6 rv add [$RV_CIDNUMBER]{}
200600.51 6 tapi Reply (LineEvReply) ok 66047 0
200600.52 6 callinfo MONITORMODES
200600.53 6 timer clear
200600.55 6 [Play 1] Playing
200600.59 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav)
200600.59 6 play set playid=5225
200601.61 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav]
200601.66 6 path {WAVERR_BADFORMAT} not found
200601.69 6 play set playid=5225
200601.83 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
200601.86 6 For Dialogic use: PCM 11Khz 8bit Mono
200601.91 6 rv add [Hangup Time]{1/3/2005 8:06:01 PM}
200601.94 6 Hanging up call... [srlib PlaySoundStart]
200601.98 6 RecSoundStop ok
200602.01 6 PlaySoundStop err=0
200602.04 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
200602.07 6 fnHangupCall end
200602.10 6 RunModule PLAY end
200602.13 6 play end current play (playid=0)
200602.15 6 ScriptEventCode 8001 iLineState=900
200602.18 6 LsAwaitingCalls EV_PLAY_FINISHED
200602.21 6 play end current play (playid=0)
200602.23 6 ScriptEventCode 8001 iLineState=900
200602.26 6 LsAwaitingCalls EV_PLAY_FINISHED
200602.30 6 linedevstate 2048 0 0
200602.33 6 callstate IDLE 66048 0 0
200602.36 6 WorkingMode@Idle=
200602.38 6 timer clear
200602.58 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
200602.60 6 tapi Reply (LineEvReply) ok 66030 0
200603.53 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
200603.55 6 ScriptEventCode 9008 iLineState=900
200603.58 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
200603.61 6 ReinitTelephony due to IDLE
200603.65 6 tapic lineDeallocateCall(MainCall:66048) 0
200603.91 6 lineOpen(6)=>
200603.94 6 Waiting for a call...
200603.96 6 LineHandle=66013
200603.99 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
200604.64 0 dial start any summary:|6:rdy=0|
200605.67 0 dial start any summary:|6:rdy=0|
200606.70 0 dial start any summary:|6:rdy=0|
200607.03 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
200607.06 6 ScriptEventCode 9013 iLineState=900
Market_Value.vgs
Have you checked the file?
I did not have any problems playing the file thru my speakers.
Let me make another note,. VG seems to pickup and run the script till the end and then hang up.
The file looks OK, so the problem seems to be with the Wave drivers. Can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony card only.
To remove other wave drivers got to Control Panel, double clock on System, select the Device Manager tab and go to Sound/Video/Game Controllers entry - then delete all other wave drivers.
You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager.
Could you please post a copy of VoiceGuide's Debug Printout which captures this.
I removed the wave drivers for dialogic card and uninstalled the sound card and disable it also. I then re-installed the wave driver and rebooted system.
I was able to run the dialogic "Horoscope" application with no problems, I tried to run VG afterwards and I have the same issue, I recorded the log file:
073357.16 0 sys cleanup Start
073357.33 0 sys cleanup End
073404.64 6 linedevstate 2048 0 0
073404.64 6 callstate OFFERING 66048 0 4
073404.65 6 Answer the call at 1/7/2005 7:34:04 AM
073404.67 6 lineAnswer(66048) => 66047
073404.68 6 callinfo CALLEDID
073404.68 6 callinfo ORIGIN
073404.69 6 ring 0
073405.23 6 callstate CONNECTED 66048 1 0
073405.24 6 callstate CONNECTED 66048,1,0
073405.24 6 WorkingModeTAPI@Connected=
073405.25 6 WorkingModeScript@Connected=
073405.30 6 Inband detection not enabled
073405.33 6 StartLoadedVgs at 1/7/2005 7:34:05 AM
073405.33 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\}
073405.34 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate}
073405.37 6 rv add [$RV_STARTTIME]{1/7/2005 7:34:05 AM}
073405.38 6 rv add [$RV_DEVICEID]{6}
073405.39 6 rv add [$RV_CIDNAME]{}
073405.40 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
073405.41 6 rv add [$RV_CIDNUMBER]{}
073405.43 6 tapi Reply (LineEvReply) ok 66047 0
073405.44 6 callinfo MONITORMODES
073405.45 6 timer clear
073405.46 6 [Play 1] Playing
073405.49 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav)
073405.51 6 play set playid=314131
073406.00 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav]
073406.03 6 path {WAVERR_BADFORMAT} not found
073406.05 6 play set playid=314131
073406.20 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
073406.23 6 For Dialogic use: PCM 11Khz 8bit Mono
073406.28 6 rv add [Hangup Time]{1/7/2005 7:34:06 AM}
073406.31 6 Hanging up call... [srlib PlaySoundStart]
073406.36 6 RecSoundStop ok
073406.39 6 PlaySoundStop err=0
073406.41 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
073406.47 6 fnHangupCall end
073406.49 6 RunModule PLAY end
073406.53 6 play end current play (playid=0)
073406.55 6 ScriptEventCode 8001 iLineState=900
073406.58 6 LsAwaitingCalls EV_PLAY_FINISHED
073406.61 6 play end current play (playid=0)
073406.64 6 ScriptEventCode 8001 iLineState=900
073406.66 6 LsAwaitingCalls EV_PLAY_FINISHED
073407.24 6 linedevstate 2048 0 0
073407.27 6 callstate IDLE 66048 0 0
073407.30 6 WorkingMode@Idle=
073407.32 6 timer clear
073407.51 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
073407.54 6 tapi Reply (LineEvReply) ok 66030 0
073408.51 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
073408.54 6 ScriptEventCode 9008 iLineState=900
073408.55 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
073408.59 6 ReinitTelephony due to IDLE
073408.62 6 tapic lineDeallocateCall(MainCall:66048) 0
073408.87 6 lineOpen(6)=>
073408.90 6 Waiting for a call...
073408.93 6 LineHandle=66013
073408.96 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
073408.99 0 dial start any summary:|6:rdy=0|
073410.01 0 dial start any summary:|6:rdy=0|
073411.04 0 dial start any summary:|6:rdy=0|
073411.98 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
073412.00 6 ScriptEventCode 9013 iLineState=900
Any clues here of the problem?
Is there a way you can connect to my system and check this? I realize the time zone differance since I'm in the USA but, I can come in anytime to make this work even leave the system online while you check.
I need to move past this problem and on to bigger issues in planning the layout of this whole thing and cant move past this... what would seem like a simple problem (but we know better in the real world) of just pickup and start playing the recorded message.
Well I reformated the system, removed the sound card.
The installed Windows 2000 with SP4, performed a windows update..rebooted.
1. Installed Intel 5.1.1 driver, rebooted..ran DCM with no problems..used Horoscope.exe to test the driver,..ran with no problems.
2. installed MDAC 2.8
3. Installed wave driver..rebooted
4. installed VG,..no issues on install
5. used the same file I sent you to test with and came up with the same problem or so it seems, picks up and you hear nothing on the phone, then hangs up.
Here is the log file:
203329.42 6 linedevstate 2048 0 0
203329.43 6 callstate OFFERING 66099 0 4
203329.46 6 Answer the call at 1/7/2005 8:33:29 PM
203329.47 6 lineAnswer(66099) => 66082
203329.47 6 callinfo CALLEDID
203329.47 6 callinfo ORIGIN
203329.47 6 ring 0
203330.01 6 callstate CONNECTED 66099 1 0
203330.01 6 callstate CONNECTED 66099,1,0
203330.01 6 WorkingModeTAPI@Connected=
203330.01 6 WorkingModeScript@Connected=
203330.07 6 Inband detection not enabled
203330.09 6 StartLoadedVgs at 1/7/2005 8:33:30 PM
203330.09 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\}
203330.09 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate}
203330.09 6 rv add [$RV_STARTTIME]{1/7/2005 8:33:30 PM}
203330.10 6 rv add [$RV_DEVICEID]{6}
203330.10 6 rv add [$RV_CIDNAME]{}
203330.10 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
203330.10 6 rv add [$RV_CIDNUMBER]{}
203330.11 6 tapi Reply (LineEvReply) ok 66082 0
203330.12 6 callinfo MONITORMODES
203330.12 6 timer clear
203330.12 6 [Play 1] Playing
203330.15 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav)
203330.15 6 play set playid=173940
203330.17 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2,play pss EnsureWaveOutIsOpenAndReady=>play FileMmioOpenAndAscend failed in Play_EnsureWaveOutIsOpenAndReady] [C:\Program Files\VoiceGuide\Scripts\Palm Beach RealEstate\Market Value.wav]
203330.18 6 play set playid=173940
203330.79 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
203330.80 6 For Dialogic use: PCM 11Khz 8bit Mono
203330.82 6 rv add [Hangup Time]{1/7/2005 8:33:30 PM}
203330.83 6 Hanging up call... [srlib PlaySoundStart]
203330.83 6 RecSoundStop ok
203330.84 6 PlaySoundStop err=0
203330.84 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
203330.85 6 fnHangupCall end
203330.86 6 RunModule PLAY end
203330.86 6 play end current play (playid=0)
203330.87 6 ScriptEventCode 8001 iLineState=900
203330.87 6 LsAwaitingCalls EV_PLAY_FINISHED
203330.88 6 play end current play (playid=0)
203330.89 6 ScriptEventCode 8001 iLineState=900
203330.89 6 LsAwaitingCalls EV_PLAY_FINISHED
203332.05 6 linedevstate 2048 0 0
203332.05 6 callstate IDLE 66099 0 0
203332.06 6 WorkingMode@Idle=
203332.06 6 timer clear
203332.09 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
203332.10 6 tapi Reply (LineEvReply) ok 66065 0
203333.02 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
203333.02 6 ScriptEventCode 9008 iLineState=900
203333.02 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
203333.02 6 ReinitTelephony due to IDLE
203333.05 6 tapic lineDeallocateCall(MainCall:66099) 0
203333.27 6 lineOpen(6)=>
203333.27 6 Waiting for a call...
203333.27 6 LineHandle=66048
203333.28 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
203333.91 0 dial start any summary:|6:rdy=0|
203334.91 0 dial start any summary:|6:rdy=0|
203335.91 0 dial start any summary:|6:rdy=0|
203336.29 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
203336.29 6 ScriptEventCode 9013 iLineState=900
203349.43 0 sys cleanup Start
203349.43 0 sys cleanup End
I hope this helps.
THe credit card demo script does not work for me also, the same problem happens.
Dialogic card answers the call and then hangs up.
