Guest Guest_Doug Report post Posted 01/04/2005 04:00 AM I have a Dialogic card 2/21D and unzipped the voice recordings in MuLaw 8kHz 8bit Mono as recommended on your web site. However, there were some files that did not have a converted file. For example, all voice recording files starting with "aa_" and "vmsend" do not have a MuLaw 8kHz 8bit Mono recording. Therefore, when using the Auto Attendant the default voice recordings do not work since they are in PCM format. I converted the recordings from PCM to MuLaw using the Sound Recorder program, however, the conversion does not produce as good a quality voice recording as in the ones in your ZIP file. Do you have a version of the MuLaw zip file that replaces all default recordings in your product? Thanks Share this post Link to post
SupportTeam Report post Posted 01/04/2005 04:18 AM The current uLaw sound file update does not include the recently added "aa_" and "vmsend" sound files. Please unzip attached file in the \voice\ subdirectory and see how these work for you. voice_ulaw.zip Share this post Link to post
