Voicemail Retrieve
When using the "Voicemail Retrieve" module there does not seem to be an option to exit the module. The only options mentioned are the following:
1 - to listen to new messages
2 - to listen to saved messages
3 - change your greeting
4 - change your mailbox PIN number
Once all voicemail messages have been retrieved what is the prodecure for exiting the Voicemail Retrieve module to return the the path in the script?
See http://www.voiceguide.com/vgDownload.htm from where you can download the VoiceGuide Voicemail Menus guide.
The voicemail menus are also listed in the Help file ( http://www.voiceguide.com/vghelp/html/voic...cemailMenus.htm )
Basically the voicemail scripts are designed to allow user to press 0 to exit the voicemail scripts.
You can of course change how the voicemail system behaves by changing the voicemail scripts yourself (see \system\vm\ subdirectory).
