Getting Called Number
I need to get the called number (not called id). What's the $RV variable name? And also does my digital phone line support this by looking at the log:
033027.40 6 linedevstate 2048 0 0
033027.40 6 callstate OFFERING 66429 0 4
033027.45 6 Lev_CallerID [0832968886,,0000]
033027.45 6 rv add [DNIS]{0000}
033027.45 6 callinfo CALLEDID
033027.45 6 callinfo ORIGIN
033027.45 6 ring 0
033033.40 6 ring 2
033033.42 6 No old processes from last call (could not obtain handle) 1568, 0
033033.42 6 Answer the call at 1/5/2005 3:30:33 AM
033033.42 6 lineAnswer(66429) => 65866
033033.95 6 callstate CONNECTED 66429 1 0
033033.95 6 callstate CONNECTED 66429,1,0
033033.95 6 WorkingModeTAPI@Connected=
033033.95 6 WorkingModeScript@Connected=
033033.00 6 Inband detection not enabled
033033.00 6 StartLoadedVgs at 1/5/2005 3:30:33 AM
033033.00 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Test\}
033033.00 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Test}
033033.00 6 rv add [$RV_STARTTIME]{1/5/2005 3:30:33 AM}
033033.00 6 rv add [$RV_DEVICEID]{6}
033033.00 6 rv add [$RV_CIDNAME]{}
033033.00 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
033033.00 6 rv add [$RV_CIDNUMBER]{0832968886}
033033.00 6 tapi Reply (LineEvReply) ok 65866 0
033033.00 6 callinfo MONITORMODES
033034.01 6 timer clear
033034.01 6 [Play CID] Playing
033034.01 6 [Play CID] Playing ()
Looks like the dialed number (DNIS) data is sent, but the data is set to '0000'.
The RV you use to access the dialed number is:
$RV[DNIS]
look at this line in the trace:
it shows that VG created $RV[DNIS] for you to use later...
What type of line are you using? Please give more info about your setup.
The lines are normal analogue lines from the telco (no PBX) but I've asked them to add CLI and other ISDN features so it should behave like an ISDN.
Usually the only way to transmit Dialed Number info on analog lines is by Inband Signaling, which is not used here...
If you get some meaningful data (other then "0000") for the DNIS field please let us know.
