Call Transfer Behind Nortel Ksu
Greetings all --
I am running into a couple of small problems... I am very impressed with the Voice Guide software, but I am having issues getting it to work how I want it...
Here's what I have:
Nortel MICS KSU w/ 8 voice lines
Two ATA/2 Analog adapters to run the voice modems
Two Creative Labs Voice Modems
Here's what we've been doing in the past:
We have a help desk located outside of our office, we have been using the voice mail system to transfer calls to our help desk by using another line on the KSU and essentially "conferencing" the two parties together.... We are running into two problems with this scenario... We have (on many occassions) run into problems where if four people call into the help desk, *ALL* of our lines are taken (because it uses a second line for each call)... The second problem that is through the translations in the phone KSU and voicemail system, there is a lot of loss of sound and it is sometimes hard to hear the other party...
Here's what I want to be able to do:
When someone dials into the help desk, have Voiceguide simply answer the phone, say "Please hold while your call is connected", flash the line on the and dial a transfer code, the immediately drop the call...
Here's my problems:
If anyone is familiar with Nortel KSU's and the ATA/2 adapters, you will know that in order to transfer a call on an ATA you have the flash the line, then dial *70 (or *71 for host signaling) + 9,phone number..... I am having mega problems getting the link times to work correctly with my KSU and/or carrier... I have included a debug log and I think I see the problem, but I am not sure where to edit the settings for the link times...
Also, does Voice guide have problems with dialing the "*" key?
192721.66 0 Script Load C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\AutoAttendant.vgs
192721.66 0 Loaded Script Id 3: C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\AutoAttendant.vgs
192721.66 0 Erasing Script (new loaded) Id 1
192736.29 0 callstate OFFERING 65799 0 4
192736.30 0 Answer the call at 1/6/2005 7:27:36 PM
192736.30 0 lineAnswer(65799) => 66055
192736.30 0 ring 1
192736.30 0 callstate ACCEPTED 65799 0 0
192737.23 0 tapi Reply (LineEvReply) ok 66055 0
192737.23 0 callstate CONNECTED 65799 0 0
192737.23 0 callstate CONNECTED 65799,0,0
192737.23 0 WorkingModeTAPI@Connected=
192737.23 0 WorkingModeScript@Connected=
192737.24 0 Inband detection not enabled
192737.24 0 StartLoadedVgs at 1/6/2005 7:27:37 PM
192737.24 0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant\}
192737.24 0 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\more sample scripts\AutoAttendant}
192737.24 0 rv add [$RV_STARTTIME]{1/6/2005 7:27:37 PM}
192737.24 0 rv add [$RV_DEVICEID]{0}
192737.26 0 rv add [$RV_CIDNAME]{}
192737.26 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
192737.26 0 rv add [$RV_CIDNUMBER]{}
192737.26 0 timer clear
192737.26 0 [Welcome] Number Input
192737.26 0 [Welcome] Playing ()
192737.26 0 ScriptEventCode 8001 iLineState=1300
192737.27 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
192737.27 0 timer set 2 EV_TIMEOUT_REPLAYMSG
192739.41 0 timer fired EV_TIMEOUT_REPLAYMSG
192739.41 0 ScriptEventCode 9005 iLineState=1301
192739.41 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
192739.41 0 [Welcome] Playing ()
192739.41 0 ScriptEventCode 8001 iLineState=1300
192739.41 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
192739.43 0 timer set 2 EV_TIMEOUT_REPLAYMSG
192741.62 0 timer fired EV_TIMEOUT_REPLAYMSG
192741.62 0 ScriptEventCode 9005 iLineState=1301
192741.62 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
192741.62 0 [Welcome] Playing ()
192741.62 0 ScriptEventCode 8001 iLineState=1300
192741.62 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
192741.62 0 timer set 2 EV_TIMEOUT_REPLAYMSG
192743.68 0 dtmf 3 (65799,51,2)
192743.68 0 ScriptEventCode 51 iLineState=1301
192743.68 0 LsGetNbrsRxDigits 3
192743.68 0 [Welcome] Number Input 3
192743.70 0 rv add [Welcome]{3}
192743.70 0 AddRVns [Welcome_PathTaken]{matched}
192743.70 0 timer clear
192743.70 0 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
192744.04 0 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
192744.04 0 ScriptEventCode 9012 iLineState=1900
192744.04 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
192744.04 0 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
192744.04 0 [service] Blind Transfer to !,*70,223 (Generate)
192744.04 0 ScriptEventCode 9602 iLineState=1900
192744.04 0 LsXferStart EV_TAPI_GENERATE
192744.05 0 timer set 1 EV_HOOKFLASHFINISHED
192745.15 0 timer fired EV_HOOKFLASHFINISHED
192745.15 0 ScriptEventCode 9200 iLineState=1905
192745.15 0 LsXferPlayVts EV_HOOKFLASHFINISHED
192745.15 0 tapic lineGenerateDigits(65799,!,*70,223,0) => 0
192745.27 0 generate LINEGENERATETERM_CANCEL
192745.27 0 timer set 1 EV_TAPI_GENERATE
192746.35 0 timer fired EV_TAPI_GENERATE
192746.35 0 ScriptEventCode 9602 iLineState=1905
192746.35 0 LsXferPlayVts EV_TAPI_GENERATE
192746.35 0 timer set 3 EV_TIMEOUT_HANGUP
192749.63 0 timer fired EV_TIMEOUT_HANGUP
192749.63 0 ScriptEventCode 9001 iLineState=1905
192749.63 0 LsXferPlayVts EV_TIMEOUT_HANGUP
192749.63 0 rv add [Hangup Time]{1/6/2005 7:27:49 PM}
192749.63 0 Hanging up call...
192749.63 0 RecSoundStop ok
192749.65 0 PlaySoundStop err=0
192749.65 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
192749.65 0 fnHangupCall end
192750.82 0 callstate DISCONNECTED 65799 1 0
192750.82 0 ScriptEventCode 9250 iLineState=900
192750.82 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
192750.82 0 rv add [Hangup Time]{1/6/2005 7:27:50 PM}
192750.82 0 Hanging up call...
192750.82 0 RecSoundStop ok
192750.84 0 PlaySoundStop err=0
192750.84 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
192750.84 0 fnHangupCall end
192750.85 0 callstate IDLE 65799 0 0
192750.85 0 WorkingMode@Idle=
192750.85 0 timer clear
192750.85 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
192750.85 0 tapi Reply (LineEvReply) ok 66327 0
192750.85 0 tapi Reply (LineEvReply) ok 65696 0
192751.84 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
192751.84 0 ScriptEventCode 9008 iLineState=900
192751.84 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
192751.84 0 ReinitTelephony due to IDLE
192751.84 0 tapic lineDeallocateCall(MainCall:65799) 0
192751.85 0 lineOpen(0)=>
192751.85 0 Waiting for a call...
192751.85 0 LineHandle=66466
192751.85 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
192752.66 0 dial start any summary:|0:rdy=0|
192753.66 0 dial start any summary:|0:rdy=0|
192754.66 0 dial start any summary:|0:rdy=0|
192755.13 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
192755.13 0 ScriptEventCode 9013 iLineState=900
Many thanks!!!
Sean Brown - sbrown@netmanage.net
Datacenter Operations
U.S. Network Management, Inc.
www.netmanage.net
From what you say it sounds like in the 'extension to transfer to' field you should just specify:
*70,9,phone number
currently it looks like you have specified:
!,*70,223
Another way of doing it is to have 4 play modules - with 1st play module playing:
second play module playing:
*70
third play module playing:
9
and fourth play module playing the phone number.
the 4 play modules should be linked by 'Timeout' paths - each path timing out after a second or so.
If you were using a using a Dialogic card then you could play !,*70,9,phone number from a single play module.
The main problem I have is that the hookswitch is not long enough, what will happen as it stands now is to to the hookswitch and it will play the DTMF tones on the first line, not the "flashed" dial tone...
What will happen, when the phone picks up, it will click briefly, then I will hear the *70,223 then it will hang-up, thinking it has transferred the call, but since the hookflash never worked it just disconnects the call.
from http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm :
Most modems cannot vary the length of their hookflash, and if their default length does not match the length required by your PBX / Telephone Network then you will not be able to use that modem to transfer/conference calls.
Telephony Cards allow the hookflash length to be set by the user – ensuring that a Telephony Card can be configured to allow it to successfully perform call transfers and conferencing. This is why it is highly recommended to use a Telephony Card if your application needs to do call transfers / conferencing.
