Guest jmiller808 Report post Posted 01/07/2005 05:05 PM so far i have only noticed this problem when the call is picked up by an answering machine. you can see that the log file shows OutDial_Result being set to Contacted_AM. 100335.59 6 AddRVns [OutDial_Result]{Contacted_AM} if you look further down in the log you can see where i have some vb script that is trying to display this value using the MsgBox function. 100349.20 6 [Run VB Script 2] Running VB Script... 100349.20 6 rv replace start: [MsgBox("OutDial_Result: $RV[OutDial_Result]") ] and after the replace happens the call to msgbox 100349.20 6 rv replace end: [MsgBox("OutDial_Result: ") can someone tell me what is going wrong? my vg script that handles a human contact has no problem with this variable and the vbscript i am using for notconnected is not having a problem with this variable. here is the full log for the call 100335.58 6 callstate DISCONNECTED 66122 16 0 100335.58 6 ScriptEventCode 9250 iLineState=5200 100335.58 6 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT 100335.58 6 rv add [Lead_no]{12345} 100335.58 6 rv add [Lead_Phone]{3192907922} 100335.58 6 rv add [OutDial_RetriesLeft]{0} 100335.58 6 rv add [$RV_STARTTIME]{1/7/2005 10:03:35 AM} 100335.58 6 rv add [$RV_DEVICEID]{6} 100335.58 6 rv add [$RV_CIDNAME]{} 100335.58 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 100335.58 6 rv add [$RV_CALLEDNUMBER]{9,13192907922} 100335.58 0 dial callque delete id=15 100335.59 6 AddRVns [OutDial_Result]{Contacted_AM} 100335.59 6 AM - wait for end of welcome message... 100335.59 6 dial awaiting end of answering machine message (lvl:10 for 20) 100335.59 6 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_6.wav] ok 100335.59 6 timer set 120 EV_TIMEOUT_HANGUP 100349.11 6 ScriptEventCode 9300 iLineState=1152 100349.11 6 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED 100349.16 6 RecSoundStop ok 100349.16 6 timer set 1 EV_REC_FINISHED 100349.16 6 ScriptEventCode 8003 iLineState=1152 100349.17 6 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED 100349.17 6 rv replace start: [$RV[AmWelcMsg_RecLen100ms]] 100349.17 6 rv ns [Lead_no]{12345} [Lead_Phone]{3192907922}[OutDial_RetriesLeft]{0} 100349.17 6 rv replace end: [] 100349.17 6 am msglen=0, minrequired=20 100349.17 6 Run Answer Machine script [C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\Superleads - AM.vgs] 100349.17 2 tr NewVgsVgm_Goto C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\Superleads - AM.vgs,,,,,0 100349.17 6 rv add [scriptEnd_Time]{1/7/2005 10:03:49 AM} 100349.17 6 rv add [scriptEnd_Goto_Script]{C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\Superleads - AM.vgs} 100349.19 6 rv add [scriptEnd_Goto_Module]{} 100349.19 6 rv add [scriptStart_Time]{1/7/2005 10:03:49 AM} 100349.19 0 Script Load C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\Superleads - AM.vgs 100349.19 6 Loaded C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\Superleads - AM.vgs into:2 100349.19 6 AddRVns [scriptsPath]{C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\} 100349.19 6 AddRVns [scriptPath]{C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts} 100349.20 6 cl NewVgsVgm_RunModule module not found: 100349.20 6 timer clear 100349.20 6 [Run VB Script 2] Running VB Script... 100349.20 6 rv replace start: [MsgBox("OutDial_Result: $RV[OutDial_Result]") ] 100349.20 6 rv ns [Lead_no]{12345} [Lead_Phone]{3192907922}[OutDial_RetriesLeft]{0}[scriptEnd_Time]{1/7/2005 10:03:49 AM}[scriptEnd_Goto_Script]{C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\Superleads - AM.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{1/7/2005 10:03:49 AM}[scriptsPath]{C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts\}[scriptPath]{C:\Documents and Settings\Josh\Desktop\Download\Voice Guide\Scripts} 100349.20 6 rv replace end: [MsgBox("OutDial_Result: ") Share this post Link to post
SupportTeam Report post Posted 01/08/2005 12:37 AM Please update your system to use the attached .exe Applying this fix will let you access the $RV[OutDial_Result] when answering machine answers the call as well. VgMulti_5.2.3050.zip Share this post Link to post
MannyTC Report post Posted 01/08/2005 01:54 AM Is there a place we can see the changes that are made in the various builds that you upload that are scattered around on the Support Forum? I see new ones from time to time and wonder what it fixes? Thanks for your help Share this post Link to post
