Cannot Install Voiceguide 2.9.1 Version
I tried to download the older version of VoiceGuide 2.9.1 and recieve the following error when trying to install on Windows 2000 server SP4:
Cannot find VBRUN300.DLL!!!
I cannot get the VG to work on my system even though everything else works:
talker
Horoscope
This all works on there own.
I have installed VG 5.2.3018 on Windows 2000 Server with SP4, removed sound card from system and re-installed the Wave Driver, after re-boot.
My error log reads:
134245.44 6 linedevstate 2048 0 0
134245.45 6 callstate OFFERING 66441 0 4
134245.45 6 Answer the call at 1/8/2005 1:42:45 PM
134245.47 6 lineAnswer(66441) => 66458
134245.47 6 callinfo CALLEDID
134245.47 6 callinfo ORIGIN
134245.47 6 ring 0
134246.01 6 callstate CONNECTED 66441 1 0
134246.01 6 callstate CONNECTED 66441,1,0
134246.01 6 WorkingModeTAPI@Connected=
134246.01 6 WorkingModeScript@Connected=
134246.06 6 Inband detection not enabled
134246.07 6 StartLoadedVgs at 1/8/2005 1:42:46 PM
134246.07 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate\}
134246.07 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate}
134246.07 6 rv add [$RV_STARTTIME]{1/8/2005 1:42:46 PM}
134246.08 6 rv add [$RV_DEVICEID]{6}
134246.08 6 rv add [$RV_CIDNAME]{}
134246.08 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
134246.08 6 rv add [$RV_CIDNUMBER]{}
134246.09 6 tapi Reply (LineEvReply) ok 66458 0
134246.09 6 timer clear
134246.09 6 [Play 1] Playing
134246.09 6 [Play 1] Playing (C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate\Market Value.wav)
134246.10 6 play set playid=967901
134246.13 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Palm-Beach-RealEstate\Market Value.wav]
134246.14 6 path {WAVERR_BADFORMAT} not found
134246.14 6 play set playid=967901
134246.15 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
134246.16 6 For Dialogic use: PCM 11Khz 8bit Mono
134246.16 6 rv add [Hangup Time]{1/8/2005 1:42:46 PM}
134246.17 6 Hanging up call... [srlib PlaySoundStart]
134246.17 6 RecSoundStop ok
134246.18 6 PlaySoundStop err=0
134246.19 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
134246.19 6 fnHangupCall end
134246.20 6 RunModule PLAY end
134246.21 6 play end current play (playid=0)
134246.21 6 ScriptEventCode 8001 iLineState=900
134246.22 6 LsAwaitingCalls EV_PLAY_FINISHED
134246.22 6 play end current play (playid=0)
134246.23 6 ScriptEventCode 8001 iLineState=900
134246.23 6 LsAwaitingCalls EV_PLAY_FINISHED
134246.24 6 callinfo MONITORMODES
134248.04 6 linedevstate 2048 0 0
134248.05 6 callstate IDLE 66441 0 0
134248.06 6 WorkingMode@Idle=
134248.06 6 timer clear
134248.07 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
134248.08 6 tapi Reply (LineEvReply) ok 66407 0
134249.05 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
134249.07 6 ScriptEventCode 9008 iLineState=900
134249.07 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
134249.07 6 ReinitTelephony due to IDLE
134249.09 6 tapic lineDeallocateCall(MainCall:66441) 0
134249.30 6 lineOpen(6)=>
134249.32 6 Waiting for a call...
134249.32 6 LineHandle=66424
134249.32 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
134249.55 0 dial start any summary:|6:rdy=0|
134250.55 0 dial start any summary:|6:rdy=0|
134251.55 0 dial start any summary:|6:rdy=0|
134252.33 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
134252.33 6 ScriptEventCode 9013 iLineState=900
Any help would be great..
Just search for VBRUN300.DLL in Google and you'll get plenty of hits for where you can download it from.
Does the Calling Card demo script work for you in v5.2.3 ?
