Evaluate Function Looses The 0
Hi
The evaluate function looses the 0 (zero) in the CLI. Example the CLI is 0835555551 it only assigns the result as 835555551. How do I fix this?
[Evaluate]
Type=Evaluate
DispSize=69
Txt=Evaluate the Result Variable specified, and select the path which matches the current value of the Result Variable
Expression=$RV_CIDNUMBER
ExprNewRV=CLI
ExprStoreRV=1
ExprStoreInGlobalRV=0
on {timeout 0} goto [say Numbers 15]
on {true} goto [say Numbers 15]
Position=93,33
[say Numbers 15]
Type=Say Numbers
DispSize=69
Txt=Say the number, amount, date or the digits. See the list o options to see how the number supplied can be interpreted and spoken out...
PlayFile2=$RV[CLI]
Replay=0,0
SayNbrType=Digits
on {timeout 0} goto [say Numbers 14]
Position=93,148
[say Numbers 14]
Type=Say Numbers
DispSize=69
PlayFile2=$RV_CIDNUMBER
Replay=0,0
SayNbrType=Digits
on {timeout 0} goto [Hangup]
Position=95,254
Specify:
"$RV_CIDNUMBER"
or:
Cstr($RV_CIDNUMBER)
as the expression to evaluate...
otherwise it evaluates input as a number and the leading zero will get dropped...
