Can't Hear Any Sound.
Dear sir or Madam,
I had connectd a extenal voice modem to my PC installing VoiceGuide.
VoiceGuide can work norming in a waiting call status. When I place a call to it, voiceGuide can dectect the call and the status change to 'Playing D:\..\mywavefile'. But I can not hear any sound in my phoneset. Is my sounds file format not correct? I have saved my sounds file as windows PCM 8kHZ, 16 bit, Mono format. And the sound file can be plaied normally in media player. Could you tell me what is the problem? Thanks
Petty Wang
Sounds like the cards Wave drivers were not correctly installed - can you
try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first. Try calling in after doing this, and if the sound can be heard over the phone you can then try to re-install your sound card drivers.
You may have to disable the sound card altogether as well to stop Windows from automatically loading it's drivers - to do this just select "Disable" and then select "Uninstall" from the Device Manager.
I have do following what you say. I the problem still not be settled. I have captured the VoiceGuide even log as below:
105456.25 0 callstate OFFERING 66168 0 4
105456.27 0 ring 1
105457.73 0 ring 2
105457.75 0 Answer the call at 2005/01/15 10:54:57
105457.75 0 lineAnswer(66168) => 66185
105457.75 0 callstate ACCEPTED 66168 0 0
105500.08 0 tapi Reply (LineEvReply) ok 66185 0
105500.09 0 callstate CONNECTED 66168 0 0
105500.09 0 callstate CONNECTED 66168,0,0
105500.09 0 WorkingModeTAPI@Connected=
105500.09 0 WorkingModeScript@Connected=
105500.09 0 Inband detection not enabled
105500.09 0 StartLoadedVgs at 2005/01/15 10:55:00
105500.09 0 AddRVns [scriptsPath]{D:\IVR\test\}
105500.09 0 AddRVns [scriptPath]{D:\IVR\test}
105500.09 0 rv add [$RV_STARTTIME]{2005/01/15 10:55:00}
105500.09 0 rv add [$RV_DEVICEID]{0}
105500.09 0 rv add [$RV_CIDNAME]{}
105500.09 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
105500.09 0 rv add [$RV_CIDNUMBER]{}
105500.09 0 timer clear
105500.11 0 [Play 1] Playing
105500.11 0 [Play 1] Playing (test.wav)
105500.11 0 play set playid=628125
105500.53 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>wavec waveOutOpen(0x170214, 0x0, 0x1701e0, 0x3032a, 0x1701b8, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] [D:\IVR\test\test.wav]
105500.53 0 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
105500.53 0 timer set .2 EV_TIMEOUT_REPLAYMSG
105500.53 0 RunModule PLAY end
105500.53 0 play end current play (playid=0)
105500.53 0 ScriptEventCode 8001 iLineState=1100
105500.55 0 LsPlayMsg EV_PLAY_FINISHED
105500.55 0 timer set 5 EV_TIMEOUT_REPLAYMSG
105505.91 0 timer fired EV_TIMEOUT_REPLAYMSG
105505.91 0 ScriptEventCode 9005 iLineState=1101
105505.91 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
105505.91 0 [Play 1] Playing (test.wav)
105505.91 0 play set playid=633921
105506.33 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>wavec waveOutOpen(0x170214, 0x0, 0x1701e0, 0x3032a, 0x1701b8, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] [D:\IVR\test\test.wav]
105506.33 0 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
105506.33 0 timer set .2 EV_TIMEOUT_REPLAYMSG
105506.33 0 play end current play (playid=0)
105506.34 0 ScriptEventCode 8001 iLineState=1100
105506.34 0 LsPlayMsg EV_PLAY_FINISHED
105506.34 0 timer set 5 EV_TIMEOUT_REPLAYMSG
105511.80 0 timer fired EV_TIMEOUT_REPLAYMSG
105511.80 0 ScriptEventCode 9005 iLineState=1101
105511.80 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
105511.80 0 [Play 1] Playing (test.wav)
105511.80 0 play set playid=639812
105512.22 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7,play pss EnsureWaveOutIsOpenAndReady=>wavec waveOutOpen(0x170214, 0x0, 0x1701e0, 0x3032a, 0x1701b8, 0x10000) => 7 (MMSYSERR_NOMEM) ... hli->hWaveOut=0x0] [D:\IVR\test\test.wav]
105512.22 0 err wav file not ready to play. Header incomplete. Lets wait a little while and try again.
105512.22 0 timer set .2 EV_TIMEOUT_REPLAYMSG
105512.22 0 play end current play (playid=0)
105512.23 0 ScriptEventCode 8001 iLineState=1100
105512.23 0 LsPlayMsg EV_PLAY_FINISHED
105512.23 0 timer set 10 EV_TIMEOUT_HANGUP
105512.23 0 rv add [Hangup Time]{2005/01/15 10:55:12}
105512.23 0 Hanging up call... [No Paths leaving Play module [Play 1]]
105512.23 0 RecSoundStop ok
105512.23 0 PlaySoundStop err=0
105512.23 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105512.25 0 fnHangupCall end
105513.25 0 callstate DISCONNECTED 66168 1 0
105513.25 0 ScriptEventCode 9250 iLineState=900
105513.25 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
105513.25 0 rv add [Hangup Time]{2005/01/15 10:55:13}
105513.25 0 Hanging up call...
105513.25 0 RecSoundStop ok
105513.25 0 PlaySoundStop err=0
105513.25 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105513.27 0 fnHangupCall end
105513.27 0 callstate IDLE 66168 0 0
105513.27 0 WorkingMode@Idle=
105513.27 0 timer clear
105513.27 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
105513.27 0 tapi Reply (LineEvReply) ok 66014 0
105513.27 0 tapi Reply (LineEvReply) ok 65997 0
105514.30 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
105514.30 0 ScriptEventCode 9008 iLineState=900
105514.30 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
105514.30 0 ReinitTelephony due to IDLE
105514.30 0 tapic lineDeallocateCall(MainCall:66168) 0
105514.33 0 lineOpen(0)=>
105514.33 0 Waiting for a call...
105514.33 0 LineHandle=65980
105514.33 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
105514.34 0 dial start any summary:|0:rdy=0|
105515.34 0 dial start any summary:|0:rdy=0|
105516.34 0 dial start any summary:|0:rdy=0|
105517.34 0 dial start any summary:|0:rdy=0|
105517.61 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
105517.61 0 ScriptEventCode 9013 iLineState=900
105548.48 0 sys cleanup Start
105548.48 0 sys cleanup End
Could you help me to analyse it and tell the potential cause?
Looks lie VoiceGuide cannot read in your test.wav file.
Does the system play sound files OK when you use the sample scripts provided with VoiceGuide? eg the credit card payment application?
Do the samples scripts (eg: the Calling card payment script) work OK when they are selected as the script to use for answered calls?
Looking at the trace closer we can see that the wave drivers for your device are actually returning an error whenever we even try to open them:
Best to probably just try using a different modem or better yet just get a Dialogic card.
