Guest jmiller808 Report post Posted 01/17/2005 03:57 PM i am having a problem with voice guide sitting at "hanging up call". This happens when i exit voice guide while there are still calls in the que and then restart the program. when restarting the program all lines initially have the message "waiting for call" then after a second they change to "Hanging up call" and never come out of that. the reason i am exiting voice guide is to temporarily stop making calls but would like to preserve the que so i can start calling again after a short time. can anyone explain what is going on here? Thanks, Josh Share this post Link to post
SupportTeam Report post Posted 01/17/2005 10:56 PM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option, then enable the 'save to file' option. Which version of VoiceGuide are you using? Share this post Link to post
Guest jmiller808 Report post Posted 01/18/2005 05:47 PM i am using version 5.2.3050 will i be able to get an event trace log if there is no call being made? i start the program and it immediately moves from "waiting for call" to "hanging up call" and then sits there. no number has been dialed and no script has been executed at this point. Share this post Link to post
SupportTeam Report post Posted 01/18/2005 10:33 PM After you enable the 'save to file' option just exit VoiceGuide, then start VG again. The log files will be created in /log/ subdirectory immediately. Share this post Link to post
Guest jmiller808 Report post Posted 01/19/2005 07:16 PM here is a zip file containing the logs. after i start the program up again after an exit. log.zip Share this post Link to post
SupportTeam Report post Posted 01/19/2005 10:50 PM Trace shows that when VoiceGuide is started it finds some outgoing calls queued in the OutDial database, and it proceeds to try and make the calls - but the Dialogic card's TAPI driver replies with a RESOURCE UNAVAILABLE error when an attempt to make the outbound call is made. See if either of the following resolves the problem: When exiting VG try first stopping all the calls on the system by disabling dialing out on the lines (View->Line Device Config menu), then wait for all calls to complete before exiting VG. Restart Dialogic service from DCM before starting VG again. I can see that you are able to somehow start VoiceGuide OK as you have been bale to run other tests with outgoing calls connecting here: http://voiceguide.com/forums/index.php?showtopic=2395 From the traces: 121846.72 5 Dialing: 15736422864 121846.72 5 MakeCall => 66253 121846.72 5 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 121846.72 5 TapiCbTrigSet 66253 7002 121846.72 5 tapi Reply (LineEvReply) err 66253 LINEERR_RESOURCEUNAVAIL [8000004B] 121846.718 tapic lineMakeCall(0x101e3, 0x1c0468, 15736422864, 0, 0x12f00c) PERFECTCALL/PAMDOPTEN 121846.718 tapic lineMakeCall => 66253 121846.718 tapie LINE_REPLY(5, 0x0, 0x102cd, 0x8000004b) Share this post Link to post
