Dialer Bug?
Hi There,
Our outgoing call was stopped by the system itself last weekend. After the investigation, we found out the last number that voice guide system called was 562.425.0000 (the phone number with . symbol), after that, the system was working not properly for whole day.
I'd like to know if the . symbol in call list file was the reason of that problem?
Regards,
Jack
Have you had the log files enabled?
Try reproducing the problem and please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
You can enable the automatic saving of the logs to files in \log\ directory as well.
