Guest Jack_VR Report post Posted 01/20/2005 02:40 PM Hi There, I just upgraded Voice Guide from professional version to enterprise. But right after the upgrading, my hung up script no longer works. What would be the reason? How can I use my hung up script in Voice Guide Enterprise version? Regards, Jack Share this post Link to post
SupportTeam Report post Posted 01/20/2005 08:36 PM You are able to use the 'on hangup' script in either version. What is the problem that you are experiencing? Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. Share this post Link to post
Guest Jack_VR Report post Posted 01/20/2005 10:01 PM Hi There, I have two scripts: One is the regular script : play voice message and hung up. The second one is a script which can save the phone number we just called into a file. Before I upgraded the license, it worked file. After I upgraded the license to enterpise version, I could see the hung up script was not called by the system. One thing I need to tell you is how I upgraded the license. I simply erase the userinfo file in voice guide folder, and start voice guide again, then the software asked for the register code, I input the data and restart the software again. Is there any problem about the upgrading processing? Regards, Jack Share this post Link to post
SupportTeam Report post Posted 01/21/2005 01:40 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the end of the call, this will allow us to see what is going wrong. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. Please alos post the scripts which you are using. One thing I need to tell you is how I upgraded the license. I simply erase the userinfo file in voice guide folder, and start voice guide again, then the software asked for the register code, I input the data and restart the software again Thats OK. Share this post Link to post
Guest Jack_VR Report post Posted 01/21/2005 02:18 PM Hi there, the log file is like: 090121.10 9 dial [1,4166304544,501210901,801,2059,MoTuWeThFrSaSu,,2,NONE,C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs,C:\Program Files\VoiceGuide\Scripts\jack draft 3.0 leave msg to answering machine.vgs,none,60,0,60,,none] 090121.57 0 dial callque update id=1 next call time 0501211001 090121.67 0 dial callque DB update returned 090121.74 9 dial found entry: tel[4166304544] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs] am[C:\Program Files\VoiceGuide\Scripts\jack draft 3.0 leave msg to answering machine.vgs] LineSelection:[] 090122.78 9 Dialing: 4166304544 090122.78 9 MakeCall => 66080 090122.81 9 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE 090122.81 9 TapiCbTrigSet 66080 7002 090122.82 0 dial start any summary:|6:dok=0|7:dok=0|8:dok=0|9:dial=0| 090123.70 9 tapi Reply (LineEvReply) ok 66080 0 090123.71 9 TapiCbTrigClear 090123.71 9 linedevstate 2048 0 0 090123.72 9 callstate DIALTONE 66199 0 0 090123.73 9 callstate DIALING 66199 0 0 090123.78 9 callstate PROCEEDING 66199 0 0 090123.85 9 callinfo CALLEDID 090123.96 9 callinfo REASON 090123.98 9 Lev_CallerID [0000,,4166304544] 090123.99 9 rv add [DNIS]{4166304544} 090124.00 9 callinfo ORIGIN 090129.51 0 sys cleanup Start 090129.52 0 sys cleanup End 090136.33 9 callstate CONNECTED 66199 1 0 090136.33 9 callstate CONNECTED 66199,1,0 090136.34 9 WorkingModeTAPI@Connected= 090136.35 9 WorkingModeScript@Connected= 090136.37 9 rv add [OutDial_RetriesLeft]{0} 090136.38 9 rv add [$RV_STARTTIME]{1/21/2005 9:01:36 AM} 090136.38 9 rv add [$RV_DEVICEID]{9} 090136.39 9 rv add [$RV_CIDNAME]{} 090136.40 9 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 090136.40 9 rv add [$RV_CALLEDNUMBER]{4166304544} 090136.41 0 dial callque delete id=1 090136.42 9 AddRVns [OutDial_Result]{Contacted_Human} 090136.43 9 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs 090136.44 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs,,,,,0 090136.45 9 rv add [scriptEnd_Time]{1/21/2005 9:01:36 AM} 090136.45 9 rv add [scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs} 090136.46 9 rv add [scriptEnd_Goto_Module]{} 090136.47 9 rv add [scriptStart_Time]{1/21/2005 9:01:36 AM} 090136.48 0 Script Load C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs 090137.08 9 eng loaded [C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs] into:2 090137.09 9 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\} 090137.09 9 eng StartModuleDefault=[intro msg] 090137.10 0 dial start any summary:|6:dok=0|7:dok=0|8:dok=0|9:hc>0| 090137.19 9 timer clear 090137.29 9 [intro msg] Playing 090137.33 9 [intro msg] Playing (C:\TeleOrder data\20 MBG INTRO HUMAN REV .wav) 090137.34 9 play set playid=437923 090137.40 9 PlaySoundStart ok [C:\TeleOrder data\20 MBG INTRO HUMAN REV .wav] 090137.41 9 timer clear 090137.41 9 RunModule PLAY end 090137.42 9 wa(76142,43792300) 090137.43 9 callinfo MONITORMODES 090253.66 9 play end current play (playid=437923) 090253.75 9 ScriptEventCode 8001 iLineState=1100 090253.76 9 LsPlayMsg EV_PLAY_FINISHED 090253.78 9 timer set 10 EV_TIMEOUT_HANGUP 090253.80 9 timer set 0 EV_TIMEOUT_GOTOMODULE 090253.90 9 ScriptEventCode 9002 iLineState=1101 090253.91 9 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 090253.94 9 timer clear 090254.03 9 [intro prompt] Playing 090254.16 9 [intro prompt] Playing (C:\TeleOrder wav files\5_New_Sound_Files_Jan3_2005\20mbg intro to the point prompt.wav) 090254.17 9 play set playid=514753 090254.23 9 PlaySoundStart ok [C:\TeleOrder wav files\5_New_Sound_Files_Jan3_2005\20mbg intro to the point prompt.wav] 090254.24 9 timer clear 090254.26 9 RunModule PLAY end 090254.27 9 wa(17058,51475300) 090254.42 9 callinfo MONITORMODES 090311.37 9 play end current play (playid=514753) 090311.39 9 ScriptEventCode 8001 iLineState=1100 090311.40 9 LsPlayMsg EV_PLAY_FINISHED 090311.41 9 timer set 5 EV_TIMEOUT_REPLAYMSG 090316.44 9 timer fired EV_TIMEOUT_REPLAYMSG 090316.45 9 ScriptEventCode 9005 iLineState=1101 090316.46 9 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 090316.48 9 [intro prompt] Playing (C:\TeleOrder wav files\5_New_Sound_Files_Jan3_2005\20mbg intro to the point prompt.wav) 090316.49 9 play set playid=537065 090316.52 9 PlaySoundStart ok [C:\TeleOrder wav files\5_New_Sound_Files_Jan3_2005\20mbg intro to the point prompt.wav] 090316.53 9 timer clear 090316.55 9 wa(17058,53706500) 090316.71 9 callinfo MONITORMODES 090316.91 0 dial start any summary:|6:dok=0|7:dok=0|8:dok=0|9:hc>0| 090317.56 9 callstate DISCONNECTED 66199 0 0 090317.58 9 ScriptEventCode 9250 iLineState=1100 090317.59 9 LsPlayMsg EV_REMOTEPARTY_DISCONNECT 090317.60 9 rv add [Hangup Time]{1/21/2005 9:03:17 AM} 090317.62 9 Hanging up call... 090317.63 9 RecSoundStop ok 090317.70 9 PlaySoundStop err=0 090317.71 9 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 090317.73 9 fnHangupCall end 090317.80 9 linedevstate 2048 0 0 090318.05 9 callstate IDLE 66199 0 0 090318.06 9 WorkingMode@Idle= 090318.07 9 timer clear 090318.09 9 After Hangup script:[C:\Program Files\VoiceGuide\Scripts\erase_number.vgs] 090318.10 0 Script Load C:\Program Files\VoiceGuide\Scripts\erase_number.vgs 090318.14 9 Loaded VbsAtHangup into:3 090318.15 9 tapi Reply (LineEvReply) ok 65704 0 090318.16 0 dial start any summary:|6:dok=0|7:dok=0|8:dok=0|9:hc>0| 090318.36 9 timer clear 090318.37 9 [erase number] Running VB Script... 090318.38 9 rv replace start: [Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 set fso = CreateObject("Scripting.FileSystemObject") set tsFile = fso.OpenTextFile("C:\TeleOrder data\DoNotCallList.txt", ForAppending, True) tsFile.WriteLine "$RV_CALLEDNUMBER" tsFile.Close set tsFile = Nothing set fso = Nothing ] 090318.40 9 rv ns none[OutDial_RetriesLeft]{0}[OutDial_Result]{Contacted_Human}[scriptEnd_Time]{1/21/2005 9:01:36 AM}[scriptEnd_Goto_Script]{C:\Program Files\VoiceGuide\Scripts\Jack draft 5.0 _ 2nd call_8bit.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{1/21/2005 9:01:36 AM}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}[Hangup Time]{1/21/2005 9:03:17 AM} 090318.42 9 eng run [ "C:\Program Files\VoiceGuide\data\vbs_9_1.vbs" //I //T:5] copy of script in: vbs_9_1.vbs 090318.44 9 Shell run Failed, err[53:File not found] Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_9_1.vbs" //I //T:5] 090318.45 9 VBScript run Failed, dShellId=0, Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_9_1.vbs" //I //T:5] 090318.47 9 rv add [Hangup Time]{1/21/2005 9:03:18 AM} 090318.48 9 Hanging up call... [Run module 2459] 090318.49 9 HangupCall_Common Mode=AfterHangupRun 090318.50 9 ReinitTelephony due to IDLE 090318.52 9 tapic lineDeallocateCall(MainCall:66199) 0 090318.91 9 lineOpen(9)=> 090318.92 9 Waiting for a call... 090318.93 9 LineHandle=65805 090318.95 9 timer set 5 EV_TIMEOUT_ATERIDLE_ALLOWOUT 090323.96 9 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 090323.97 9 ScriptEventCode 9013 iLineState=900 090417.91 0 Unloading Main Window And the script I use for hung up is : Version=5.0 DefaultModuleDisplayHeight= StartModule=erase number RunAtHangup= StartWithoutAnswer=0 CtmAsiName= [erase number] Type=Run VB Script DispSize=69 Txt=Run a VB Script. VbsFileToRun= VbsWait=1 VbScript= Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 set fso = CreateObject("Scripting.FileSystemObject") set tsFile = fso.OpenTextFile("C:\TeleOrder data\DoNotCallList.txt", ForAppending, True) tsFile.WriteLine "$RV_CALLEDNUMBER" tsFile.Close set tsFile = Nothing set fso = Nothing VbsHoldPlay= on {success} goto [Hangup] on {timeout 5} goto [Hangup] Position=15,10 [Hangup] Type=Hangup the Call DispSize=69 Txt=Hangup the call. Position=198,12 It seems like enterprise version uses a little bit different way to call the hung up script with professional version, I guess. Regards, Jack Share this post Link to post
Guest Any suggestions? Report post Posted 01/24/2005 02:41 PM Hi there, Is there any suggestion about this problem? Regards, Jack Share this post Link to post
SupportTeam Report post Posted 01/25/2005 01:18 AM The "After Hangup" script runs OK, but in the vb script: 090318.42 9 eng run [ "C:\Program Files\VoiceGuide\data\vbs_9_1.vbs" //I //T:5] copy of script in: vbs_9_1.vbs 090318.44 9 Shell run Failed, err[53:File not found] Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_9_1.vbs" //I //T:5] 090318.45 9 VBScript run Failed, dShellId=0, Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_9_1.vbs" //I //T:5] It looks like in your case the ShellHandler entry in VG.INI file is either missing or not set to anything... did you edit the VG.INI file? Find the VBScript section in your VG.INI file. It should look like this: [VBScript] UseSafeSubset=1 ShellHandler=wscript This would affect all VBScript modules in all scripts... Share this post Link to post
Guest Jack_VR Report post Posted 01/25/2005 03:01 PM Hi there, As I told you before, I didn't modify VG.ini file. The only thing I did was rename old vg.ini to vg_2lines.ini. re-run VG and created a new vg.ini (and saved a backup file named vg_4lines.ini). I send you those two files, hopefully you can find something useful for us. Regards, Jack vg_ini.zip Share this post Link to post
Guest Jack_VR Report post Posted 01/25/2005 03:25 PM Hi there, I found the reason by following your suggestion. I renamed the configuration file before I input the new registration code. I thought the system would create a new configuration file after I input the new reg-code, but it didn't. After I copied the old 2_lines configuration file back, everything seems working fine. Regards, Jack Share this post Link to post
SupportTeam Report post Posted 01/25/2005 08:43 PM I thought the system would create a new configuration file after I input the new reg-code, but it didn't. The configuration file is there to tell VoiceGuide what settings to use... if the configuration file is not present then VoiceGuide does not know what settings to use.... If you want to make a backup copy of VG.INI then do just that - make a copy, not remove the file altogether... Share this post Link to post
