Guest hannje Report post Posted 01/20/2005 04:59 PM I have a script, that has been running well for some time. I started working on another script in a different directory of the scripts directory. I allocated one phone line for testing, and started churning some code. All of the sudden, the first script stopped working. Upon investigation, I discovered that my executables in the first script directory were putting their run results files into the new script's directory. I have solved the problem by putting the full path name into the "fopen" statement, ie, I went from this sprintf(filename,"VGRUNRESULT_%d.txt",lineNumber); fp = fopen(filename, "w"); to this sprintf(filename,"C:\\Program Files\\VoiceGuide\\Scripts\\Intertrakvr\\VGRUNRESULT_%d.txt",lineNumber); fp = fopen(filename, "w"); This is cumbersome. Any way to avoid it? thanks, Share this post Link to post
SupportTeam Report post Posted 01/20/2005 08:50 PM This is really a VBScript question more then a VoiceGuide one... Specifying the full path is the best way. If you do not specify the path then the 'current' path is used - but it's up to Windows to decide what is the current path - and as you can see Windows does not set this to always be what you'd expect... You may be able to find out from what directory script is run using some of the Wsh object commands... Share this post Link to post
