Two Cards and the Linesconfig.xml
Hello
I was using one dialogic E1 card and Linesconfig.xml was configured in the same manner. Then I added upo one more card and purchased the license accordingly. But I don't know about the changes to be done in Linesconfig.xml
pl. help
amit
Some samples of Linesconfig.xml would have been included when you received VG for Dialogic.
I attach a sample of one here as well.
The attached sample is for 120 lines - just delete the second half of the Channel entries in it and you will get a config file which is appropriate when just 60 channels are used.
Sample_Config_for_120_port_using_four_E1s_ISDN.zip
