Wav File List
hi there, if i have a string that returned like this in VBS
1.wav,thousand.wav,3.wav,hundred.wav,40.wav,2.wav,dollars.wav,and.wav,30.wav
how do i make it read out the wav files ?
Please Help ...
Just place this string in any text box which is used to specify what sound files are to be played, or use the Play_Start COM command.
If the path to each of the files is not specified then VoiceGuide will search for sound files first in script's directory, then in the VoiceGuide's 'System Sound Files' directory.
