Test Using Dialogic´s Talker32
1) Dialogic d300 installed --> DCM config. ok Dialogic up.
2) Tapi driver seems to be ok
3) Wave driver seems to be ok
When I run Talker 32 --> Application talker32 hangs
If I run any sample Voiceguide it hangs as well.
I´m lost
Please, help.
Thanks in advance.
Well, I Could configure the Voiceguide running samples and it appears to work ok.
Any ideas why it didn´t work the tapi with the talker32? I guess something wrong with the tapi config.
It appears to be limited to 4 digital ports on the E1 the demo. is it correct?
Many thanks in advance.
Send an Email to sales@voiceguide.com
You will be forwarded 'VoiceGuide for Dialogic' which is a much better choice on Digital lines.
