Guest Munkhtur Report post Posted 01/31/2005 04:10 AM Hi, I'm using VG 4.8.45 on win2000 server with D/4 PCI card. I'm also using the Fire Daemon to make the VG run as service. I've a problem. When I connect to SqlServer I can't get data from SqlServer. it shows ERROR: OpenDatabase [3146:ODBC--call failed.] Share this post Link to post
SupportTeam Report post Posted 01/31/2005 05:45 AM Try running the service with different settings for the "Console Application" and the "Interact with Desktop" options... There have been some changes made in v5.x in that area - have you tired verifying if v5.2.3 works for you? v4.8.45 is quite old... Share this post Link to post
