Some Help In Vbs
hi
i need to develop a script whic do the following :
first it ask the user to leave a message(which is a question that will be answer by
his message will stor in database which will show the path of the message) after that the script will generate a number that will be told to the caller after saving his message so he can use this number to know the answer to his question ,and every thing tell now is ok ,the following vbs do all the story for the number
Const adOpenForwardOnly = 0
Const adOpenKeyset = 1
Const adOpenDynamic = 2
Const adOpenStatic = 3
set cn = CreateObject("ADODB.Connection")
set rs = CreateObject("ADODB.Recordset")
cn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Documents and Settings\alqadi\Desktop\omar test\Copy of add.mdb"
msgbox("ok")
set rs.ActiveConnection = cn
rs.Open "SELECT A FROM Table1 ", cn, adOpenStatic
'if rs.RecordCount > 0 then
rs.movelast
vg.Admin_TraceLogAdd $RV_LINEID, 5, "vbs records found OK"
iA = rs.Fields("A").Value
' sID = rs.Fields("ID").Value
' *******************************************8
maxi=iA
iA = ((iA + 7)*5)-13
sID =iA
cc = sID
'msgbox("UPDATE Table1 SET ID=" & sID & " WHERE A=" & maxi)
cn.Execute "UPDATE Table1 SET ID=" & sID & " WHERE A=" & maxi
'else
' vg.Admin_TraceLogAdd $RV_LINEID, 5, "vbs no records found"
'end if
cn.Close
Set rs = Nothing
Set cn = Nothing
Set vg = Nothing
msgbox("cc= " & cc)
the problem is i need that the Say Numbers will speak the "cc" how can i do that
thanks
You need to return the value of CC back to VoiceGuide as a Result Variable and then specify that Result Variable in the Say Number module.
Easiest way is to use the RvSet COM function.
Add this line to you VBScript after the cc is set:
vg.RvSet $RV_LINEID, "TheMagicNumber", cc
you can then use this RV:
$RV[TheMagicNumber]
In the Say Number module.
A trace capturing the call would be good here, but I think I see what the problem is - your VBScript is not returning any result back to VoiceGuide and you only have the Success path leaving from the VBScript module.
If you do not return any result then VG looks fro a Fail path.
Either return a result back to VG (use the Run_ResultReturn COM command) or specify a Fail path going to the Say numbers module...
Read: http://www.voiceguide.com/vghelp/html/modVbs.htm
You may also use brackets in the function call, changing:
to:
vg.RvSet($RV_LINEID, "TheMagicNumber", cc)
