Guest omar_f Report post Posted 01/31/2005 02:01 PM hi i need to develop a script whic do the following : first it ask the user to leave a message(which is a question that will be answer by his message will stor in database which will show the path of the message) after that the script will generate a number that will be told to the caller after saving his message so he can use this number to know the answer to his question ,and every thing tell now is ok ,the following vbs do all the story for the number Const adOpenForwardOnly = 0 Const adOpenKeyset = 1 Const adOpenDynamic = 2 Const adOpenStatic = 3 '*********************************************** set vg = CreateObject("VoiceGuide.CommandLink") set cn = CreateObject("ADODB.Connection") set rs = CreateObject("ADODB.Recordset") cn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Documents and Settings\alqadi\Desktop\omar test\Copy of add.mdb" msgbox("ok") set rs.ActiveConnection = cn rs.Open "SELECT A FROM Table1 ", cn, adOpenStatic 'if rs.RecordCount > 0 then rs.movelast vg.Admin_TraceLogAdd $RV_LINEID, 5, "vbs records found OK" iA = rs.Fields("A").Value ' sID = rs.Fields("ID").Value ' *******************************************8 maxi=iA iA = ((iA + 7)*5)-13 sID =iA cc = sID 'msgbox("UPDATE Table1 SET ID=" & sID & " WHERE A=" & maxi) cn.Execute "UPDATE Table1 SET ID=" & sID & " WHERE A=" & maxi 'else ' vg.Admin_TraceLogAdd $RV_LINEID, 5, "vbs no records found" 'end if cn.Close Set rs = Nothing Set cn = Nothing Set vg = Nothing msgbox("cc= " & cc) //////////////////////////////////// the problem is i need that the Say Numbers will speak the "cc" how can i do that thanks Share this post Link to post
SupportTeam Report post Posted 01/31/2005 02:20 PM i need that the Say Numbers will speak the "cc" how can i do that You need to return the value of CC back to VoiceGuide as a Result Variable and then specify that Result Variable in the Say Number module. Easiest way is to use the RvSet COM function. Add this line to you VBScript after the cc is set: vg.RvSet $RV_LINEID, "TheMagicNumber", cc you can then use this RV: $RV[TheMagicNumber] In the Say Number module. Share this post Link to post
Guest omar_f Report post Posted 01/31/2005 02:31 PM thank you for your reply but when i do that the after finishing the vbs it hungup the call i will send and attach. file New_Folder.rar Share this post Link to post
SupportTeam Report post Posted 01/31/2005 11:45 PM A trace capturing the call would be good here, but I think I see what the problem is - your VBScript is not returning any result back to VoiceGuide and you only have the Success path leaving from the VBScript module. If you do not return any result then VG looks fro a Fail path. Either return a result back to VG (use the Run_ResultReturn COM command) or specify a Fail path going to the Say numbers module... Read: http://www.voiceguide.com/vghelp/html/modVbs.htm You may also use brackets in the function call, changing: vg.RvSet $RV_LINEID, "TheMagicNumber", cc to: vg.RvSet($RV_LINEID, "TheMagicNumber", cc) Share this post Link to post
