dalittle Report post Posted 02/01/2005 02:41 PM When I enable play back of numbers entered, voiceguide disconnects the call at that point in the script. Here is an output of the log: 083342.14 1 callstate OFFERING 66531 0 4 083342.14 1 rv clear 083342.14 1 Answer the call at 2/1/2005 8:33:42 AM 083342.14 1 lineAnswer(66531) => 66445 083342.14 1 ring 1 083342.14 1 callstate ACCEPTED 66531 0 0 083342.19 0 dial start any summary:|1:hc>0| 083345.52 1 tapi Reply (LineEvReply) ok 66445 0 083345.52 1 callstate CONNECTED 66531 0 0 083345.52 1 callstate CONNECTED 66531,0,0 083345.53 1 WorkingModeTAPI@Connected= 083345.53 1 WorkingModeScript@Connected= 083345.53 1 Inband detection not enabled 083345.53 1 StartLoadedVgs at 2/1/2005 8:33:45 AM, v5.2.3063 083345.53 1 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Bedboard\} 083345.53 1 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Bedboard} 083345.53 1 rv add [$RV_STARTTIME]{2/1/2005 8:33:45 AM} 083345.53 1 rv add [$RV_DEVICEID]{1} 083345.53 1 rv add [$RV_CIDNAME]{} 083345.53 1 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 083345.53 1 rv add [$RV_CIDNUMBER]{} 083345.53 1 timer clear 083345.53 1 [security code] Number Input 083345.53 1 [security code] Playing (C:\Program Files\VoiceGuide\Scripts\Bedboard\securitycode.wav) 083345.53 1 play set playid=226109 083345.64 1 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Bedboard\securitycode.wav] 083345.64 1 timer clear 083345.64 1 wa(2246,22610900) 083347.23 1 dtmf 8 (66531,56,2) 083347.23 1 ScriptEventCode 56 iLineState=1300 083347.23 1 LsGetNbrsPlayWelcMsg 8 083348.22 1 PlaySoundStop err=0 083348.22 1 [security code] Number Input 8 083348.22 1 path {8} not found 083348.22 1 timer set 6 EV_TIMEOUT_ENTERDATA 083348.22 1 dtmf 1 (66531,49,2) 083348.22 1 ScriptEventCode 49 iLineState=1301 083348.22 1 LsGetNbrsRxDigits 1 083348.22 1 [security code] Number Input 81 083348.22 1 path {81} not found 083348.22 1 timer set 6 EV_TIMEOUT_ENTERDATA 083348.22 1 dtmf 3 (66531,51,2) 083348.22 1 ScriptEventCode 51 iLineState=1301 083348.22 1 LsGetNbrsRxDigits 3 083348.23 1 [security code] Number Input 813 083348.23 1 path {813} not found 083348.23 1 timer set 6 EV_TIMEOUT_ENTERDATA 083348.31 1 dtmf 1 (66531,49,2) 083348.31 1 ScriptEventCode 49 iLineState=1301 083348.33 1 LsGetNbrsRxDigits 1 083348.33 1 [security code] Number Input 8131 083348.33 1 rv add [security code]{8131} 083348.33 1 AddRVns [security code_PathTaken]{matched} 083348.33 1 timer clear 083348.33 1 [enterroom] Number Input 083348.33 1 [enterroom] Playing (C:\Program Files\VoiceGuide\Scripts\Bedboard\room number.wav) 083348.33 1 play set playid=228906 083348.44 1 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Bedboard\room number.wav] 083348.44 1 timer clear 083348.44 1 wa(1996,22890600) 083350.63 1 play end current play (playid=228906) 083350.63 1 ScriptEventCode 8001 iLineState=1300 083350.63 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 083350.63 1 eng set timer EV_TIMEOUT_REPLAYMSG time=5 083350.63 1 timer set 5 EV_TIMEOUT_REPLAYMSG 083350.73 1 dtmf 2 (66531,50,2) 083350.73 1 ScriptEventCode 50 iLineState=1301 083350.73 1 LsGetNbrsRxDigits 2 083350.73 1 [enterroom] Number Input 2 083350.73 1 path {2} not found 083350.73 1 timer set 6 EV_TIMEOUT_ENTERDATA 083351.25 1 dtmf 0 (66531,48,2) 083351.25 1 ScriptEventCode 48 iLineState=1301 083351.25 1 LsGetNbrsRxDigits 0 083351.25 1 [enterroom] Number Input 20 083351.25 1 path {20} not found 083351.25 1 timer set 6 EV_TIMEOUT_ENTERDATA 083352.56 1 dtmf 2 (66531,50,2) 083352.56 1 ScriptEventCode 50 iLineState=1301 083352.56 1 LsGetNbrsRxDigits 2 083352.56 1 [enterroom] Number Input 202 083352.56 1 path {202} not found 083352.56 1 timer set 6 EV_TIMEOUT_ENTERDATA 083353.09 1 dtmf 0 (66531,48,2) 083353.09 1 ScriptEventCode 48 iLineState=1301 083353.09 1 LsGetNbrsRxDigits 0 083353.09 1 [enterroom] Number Input 2020 083353.09 1 path {2020} not found 083353.09 1 timer set 6 EV_TIMEOUT_ENTERDATA 083353.09 1 timer clear 083353.09 1 rv add [enterroom]{2020} 083353.09 1 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\voice\GetNbrsConfirmIntro.wav],[C:\Program Files\VoiceGuide\system\voice\GetNbrsConfirmMenu.wav],[2020],Digits 083353.09 1 sVbsFunctionToUse=Digits 083353.13 1 Shell run Failed (PlayNbrs), err[53] Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_1_SayNumber.vbs" //I //T:60] 083353.14 1 VBScript run Failed, dShellId=0, Shell parameter = [ "C:\Program Files\VoiceGuide\data\vbs_1_SayNumber.vbs" //I //T:60] 083353.14 1 rv add [Hangup Time]{2/1/2005 8:33:53 AM} 083353.14 1 Hanging up call... [say Number could not start VBScript] 083353.14 1 RecSoundStop ok 083353.14 1 PlaySoundStop err=0 083353.14 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 083353.14 1 fnHangupCall end 083353.14 1 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_1_SayNumber.vbs) 083354.55 1 callstate DISCONNECTED 66531 1 0 083354.55 1 ScriptEventCode 9250 iLineState=900 083354.55 1 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 083354.56 1 rv add [Hangup Time]{2/1/2005 8:33:54 AM} 083354.56 1 Hanging up call... 083354.56 1 RecSoundStop ok 083354.56 1 PlaySoundStop err=0 083354.56 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 083354.56 1 fnHangupCall end 083354.56 1 callstate IDLE 66531 0 0 083354.56 1 WorkingMode@Idle= 083354.56 1 timer clear 083354.58 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 083354.58 1 tapi Reply (LineEvReply) ok 66480 0 083354.58 1 tapi Reply (LineEvReply) ok 66206 0 083355.56 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 083355.56 1 ScriptEventCode 9008 iLineState=900 083355.56 1 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 083355.56 1 ReinitTelephony due to IDLE 083355.56 1 tapic lineDeallocateCall(MainCall:66531) 0 083355.58 1 lineOpen(1)=> 083355.58 1 Waiting for a call... 083355.59 1 LineHandle=66394 083355.59 1 timer set 5 EV_TIMEOUT_ATERIDLE_ALLOWOUT 083356.23 0 dial start any summary:|1:rdy=0| 083401.06 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 083401.06 1 ScriptEventCode 9013 iLineState=900 083401.23 0 dial start any summary:|1:idx=0| Share this post Link to post
SupportTeam Report post Posted 02/02/2005 02:55 AM We ran a test on our test system here and the Get Numbers module played back the entered numbers fine... Which version of VoiceGuide are you using? Here is a trace from out test showing the numbers played back fine: 131824.70 7 [Get Client ID] Number Input 111222333 131824.70 7 path {111222333} not found 131824.70 7 timer set 6 EV_TIMEOUT_ENTERDATA 131825.45 7 dtmf # (65862,35,2) 131825.45 7 ScriptEventCode 35 iLineState=1301 131825.45 7 LsGetNbrsRxDigits # 131825.47 7 timer clear 131825.47 7 rv add [Get Client ID]{111222333} 131825.47 7 fn PlaySoundStartNumbers [c:\VG\system\voice\GetNbrsConfirmIntro.wav],[c:\VG\system\voice\GetNbrsConfirmMenu.wav],[111222333],Digits 131825.47 7 sVbsFunctionToUse=Digits 131825.52 7 Started SayNumber VBScript OK. (c:\VG\data\vbs_7_SayNumber.vbs) 131825.53 7 cl Play_Start c:\VG\system\voice\GetNbrsConfirmIntro.wav,1.wav,1.wav,1.wav,2.wav,2.wav,2.wav,3.wav,3.wav,3.w v,c:\VG\system\voice\GetNbrsConfirmMenu.wav 131825.55 7 play set playid=139062 131825.61 7 PlaySoundStart ok [c:\VG\system\voice\GetNbrsConfirmIntro.wav,c:\VG\system\voice\1.wav,c:\VG\system\voice\1.wav,c:\VG\system\voice\1.wav,c:\VG\system\voice\2.wav,c:\VG\system\voice\2.wav,c:\VG\system\voice\2.wav,c:\VG\system\voice\3.wav,c:\VG\system\voice\3.wav,c:\VG\system\voice\3.wav,c:\VG\system\voice\GetNbrsConfirmMenu.wav] Share this post Link to post
