Can VoiceGuide Support Arabic Language
hi
i saw that topic ,but what i mean that can (Say Numbers) speak the number enter by user in arabic
If you want the Say Number module to speak the numbers in Arabic the you will need to record the Arabic versions of sound files 1.wav - 9.waw and hundred.wav etc.
You may need to also modify the lib_num2wav.vbs script if the Arabic number grammar numbers is very different to English...
Hello,
I've done it. For any further query you may contact me at rajendrarajsri@yahoo.co.in
Rajendra
i have the Wave files in Arabic, did you modify the lib_num2wav.vbs script to say Arabic Numbers? if so, can you share it with us.
thanks
