Call Transfer
I am working on a windows xp computer with VoiceGuide 5.2.3018 Enterprise. The modem is a Dialogic D/4PCI. I am trying to transfer a call to an internal number (example 2250) instead the call is transfered to 0. Attached is the event log.
log.txt
You should be specifying just the extension number in the Transfer Call module - without the hookflash character.
If you use the ! in the Extension Number in the Transfer Call module then the hookflash will just get dialed again - resulting in two hookflashes being dialed one after another...
See the examples in the Help file: http://www.voiceguide.com/vghelp/html/modXfer.htm
The root cause of the problem was the transfer function was not enabled on the PBX for this line. Once that was enabled and the extra ! was removed the system worked. Thanks for the help.
