Can Vg Be Made To Minimize Into Tray?
The subject pretty says my question. Can Voice Gude be set to just be an icon in the tray when minimized? Right now it sits on the taskbar when you minimize it. Being that it's running 24/7, it would be les intrusive if there was just an icon in the tray by the clock. Is there a way to do this?
From VoiceGuide help file (v4.9)
VoiceGuide Command Line Options
-icon  Will minimize the application to the system tray
-hide  Will hide the main application window
-min   Will minimize the window to the taskbar
There is also a menu command which will do this (under "File" menu I think)
