Error In .Wav File Format
I was recording the wav in my notebook (windows server 2000) inside the voice guide. However, the message "error in playing file format" is played when it is connected. Please help. Thanks in advance.
Background:
-using latest voice guide.
-external modem
-running on win server 2000
123335.31 7 callstate OFFERING 65947 0 4
123335.31 7 rv clear
123335.31 7 Answer the call at 05/02/2005 12:33:35 PM
123335.31 7 lineAnswer(65947) => 65760
123335.31 7 ring 1
123335.31 7 callstate ACCEPTED 65947 0 0
123338.43 7 tapi Reply (LineEvReply) ok 65760 0
123338.43 7 callstate CONNECTED 65947 0 0
123338.43 7 callstate CONNECTED 65947,0,0
123338.43 7 WorkingModeTAPI@Connected=
123338.44 7 WorkingModeScript@Connected=
123338.44 7 Inband detection not enabled
123338.44 7 StartLoadedVgs at 05/02/2005 12:33:38 PM, v5.2.3053
123338.44 7 AddRVns [scriptsPath]{F:\temp\ivrs\}
123338.44 7 AddRVns [scriptPath]{F:\temp\ivrs}
123338.44 7 rv add [$RV_STARTTIME]{05/02/2005 12:33:38 PM}
123338.44 7 rv add [$RV_DEVICEID]{7}
123338.44 7 rv add [$RV_CIDNAME]{}
123338.44 7 AddRVns [PathApp]{E:\Program Files\VoiceGuide\}
123338.44 7 rv add [$RV_CIDNUMBER]{}
123338.46 7 timer clear
123338.46 7 [Play 1] Playing
123338.46 7 [Play 1] Playing (test.wav)
123338.46 7 play set playid=783293
123338.46 7 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [F:\temp\ivrs\test.wav]
123338.47 7 path {WAVERR_BADFORMAT} not found
123338.47 7 play set playid=783293
123338.61 7 timer clear
123338.61 7 RunModule PLAY end
123338.61 7 play end old playid returned=0 (current=783293)
123338.61 7 wa(4425,78329300)
123343.05 7 play end current play (playid=783293)
123343.05 7 ScriptEventCode 8001 iLineState=1100
123343.05 7 LsPlayMsg EV_PLAY_FINISHED
123343.06 7 timer set 5 EV_TIMEOUT_REPLAYMSG
123346.15 7 callstate DISCONNECTED 65947 32 0
123346.15 7 ScriptEventCode 9250 iLineState=1101
123346.15 7 LsPlayMsgFinished EV_REMOTEPARTY_DISCONNECT
123346.15 7 rv add [Hangup Time]{05/02/2005 12:33:46 PM}
123346.15 7 Hanging up call...
123346.15 7 RecSoundStop ok
123346.15 7 PlaySoundStop err=0
123346.16 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
123346.16 7 fnHangupCall end
123346.23 7 callstate IDLE 65947 0 0
123346.24 7 WorkingMode@Idle=
123346.24 7 timer clear
123346.27 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
123346.29 7 tapi Reply (LineEvReply) ok 65777 0
123347.18 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
123347.18 7 ScriptEventCode 9008 iLineState=900
123347.18 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123347.18 7 ReinitTelephony due to IDLE
123347.18 7 tapic lineDeallocateCall(MainCall:65947) 0
123347.23 7 lineOpen(7)=>
123347.23 7 Waiting for a call...
123347.23 7 LineHandle=65640
123347.23 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
123347.96 0 dial start any summary:|7:rdy=0|
123348.97 0 dial start any summary:|7:rdy=0|
123349.97 0 dial start any summary:|7:rdy=0|
123350.25 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
123350.25 7 ScriptEventCode 9013 iLineState=900
from http://www.voiceguide.com/vghelp/html/SoundFiles.htm :
Windows Voice Modem Wave driver can only support sound files in the following format PCM 8000Hz, 16bit, Mono. When using Voice modems all sound files must be recorded in the above format.
Dialogic Wave driver prefers sound files in the following format PCM 11025Hz, 8bit, Mono. When using a Dialogic card, all sound files should be recorded in the above format.
Do the sound files provided with VoiceGuide play OK?
Thanks for quick response.
1) the format is recorded in voiceguide itself without any futher modification.
2) we can only test it til monday. However, the sentence like "there is an error playing the file. please check the file format" can be played clearly over the phone.
Any idea? Thanks in advance.
The Script Designer does not record any sound files itself - it just starts the Sound Recorder app and you have to ensure that it will be doing the recording in the correct format...
Yes. But the format will be different? anyway, let me try it tomorrow. wish me good luck.
