How To Introduce Pauses In Tts Text
Muayyad wrote:
I want to use TTS to read the text in the text box(Text to speak ) in your SW .
I want to make a delay ( Break time ) for 1 or 2 or 3 Sec between the statments .
I'm using Cepstral TTS , what I have to insert in the text box ?
I tried to use (, .) but no delay .
See if Cepstral has any commands it accepts as part of the TTS text to specify a pause. Most TTS engines have such commands.
Else you can always split the TTS across multiple Play modules and use a timeout path to link them. Use the timeout value in the paths to specify the pause time.
