vinesh Report post Posted 02/14/2005 06:16 AM Hi there, when playing a sound file in the beginning of my script VoiceGuide it just hangs up before the sound file is done playing, the sound file is only 4 sec's long. When looking at the event log, it shows that its a timeout 10 second hangup... Share this post Link to post
vinesh Report post Posted 02/14/2005 06:40 AM i tried another longer sound file and the same thing happens : 82011.04 5 PlaySoundStart ok [C:\IVR\SMP 011-test.wav] 082011.07 5 timer clear 082011.09 5 RunModule PLAY end 082011.13 5 wa(13566,62990000) 082011.16 5 callinfo MONITORMODES 082024.74 5 wb(62990000) 082024.80 5 play end current play (playid=629900) 082024.84 5 ScriptEventCode 8001 iLineState=1100 082024.86 5 LsPlayMsg EV_PLAY_FINISHED 082024.89 5 timer set 10 EV_TIMEOUT_HANGUP 082024.91 5 timer set 15 EV_TIMEOUT_GOTOMODULE 082039.85 5 timer fired EV_TIMEOUT_GOTOMODULE 082039.87 5 ScriptEventCode 9002 iLineState=1101 082039.90 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 082039.93 5 timer clear 082039.96 5 rv add [Hangup Time]{2/14/2005 8:20:39 AM} 082039.98 5 Hanging up call... [Hangup Module] 082040.03 5 RecSoundStop ok is there a way to disable that 10 second timeout ? i've attached one of the files we using SMP_011_test.wav Share this post Link to post
SupportTeam Report post Posted 02/14/2005 10:38 PM It looks like you are using a voice modem that does not stop the previous play properly, and that is in turn causing other problems... What modem are you using? Which version of VG are you using? Could you please post the MMDDtw.txt log file (see \log\ subdirectory) which captures the entire call from the beginning. Share this post Link to post
vinesh Report post Posted 02/15/2005 06:03 AM i'm using a dialogic d/4pci card with voiceguide 5.2.3b (but i you guys gave me another vgmulti.exe so i can accept inputs as 12*00, topic http://voiceguide.com/forums/index.php?showtopic=2453) 0215vgm.txt Share this post Link to post
SupportTeam Report post Posted 02/15/2005 07:26 AM We need the MMDDtw.txt log file - see in VG's \log\ subdirectory. But looking back through the post I see that the sound file you attached and describe as being 4 seconds is in fact 13 seconds... so the original trace does not actual have any problem in it - we see VG starting playing of a 13 second sound file in full, then you have a timeout path of 15 seconds going to some other module but it looks like the script hangs up instead of taking that path. Are you sure the 15 second timeout path is specified properly? Please post the script which you are using. Share this post Link to post
vinesh Report post Posted 02/15/2005 08:51 AM sorry i've attached a zip file with the MMDDtw.txt log file, the vg test script and the sound file used... files.zip Share this post Link to post
SupportTeam Report post Posted 02/15/2005 11:25 AM The error that is happening here is that the sound files you have created are getting stopped by VoiceGuide before they get fully played. It looks like this is because the WAV file you are creating is saved with some unusual options that is confusing either the length calculations that VG makes before playing the sound file or it confuses the wav file playing routines themselves I think that if you used any of the sound files which came with VG you'll find that they play fine and do not get cut off like this. The .wav file you attached has a large 'PAD' section at the beginning of the sound file. I suspect that the Dialogic WAV drivers were playing this part as well - so effectively the wav file starts playing later then it should and VG intervenes when it detects that the sound file appears to be playing for too long and forcefully stops the playback. What sound editor are you using to create your sound files? Try opening them in normal Windows' sound editor and then saving them again in the correct format preferred by Dialogic - PCM 11kHz 8bit Mono As for the timeout path - we can see from the traces that it correctly waits and goes to the appropriate module after the correct amount of time expired, so there are no problems there... Share this post Link to post
vinesh Report post Posted 02/15/2005 01:33 PM thanks, that worked.... I dunno what editor was used, we got some studio to do that for us. I just resaved the files with Nero Wave Editor and it did the trick. Thanks alot for your guys support, much appreciated Share this post Link to post
