Guest JOSE LUIS PEREZ Report post Posted 02/17/2005 11:32 AM We have got the enterprise version and it works perfect with no problem. The only problem we see is if we want to dialer to an externat number with isdn signalling it doesn´t work. Since we hear the tones, it appears it dials with CAS signalling, but it doesn´t with isdn through the dialogic card. It´s basically to divert the call to a call center if the IVR doesn´t provide the solution to the incoming party. Any idea a potential solution? Thanks a lot José Luis Share this post Link to post
SupportTeam Report post Posted 02/17/2005 12:35 PM Pelase tell us more about your system. What Dialogic cards are you using and what types of lines are plugged into it. Could you please post a copy of VoiceGuide's Debug Printout which captures the scenario which you are describing, this will allow us to see what is going on. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. (You can enable the automatic saving of the logs to files in \log\ directory as well.) Share this post Link to post
Guest Jose Luis Perez Report post Posted 02/17/2005 05:12 PM - Our systems consist of a dialogic pri isdn card with 30 channels. - model dialogic card is d300sc pci bus. - we do work only with isdn signalling (setup messages,etc.... always on timeslot 16). obviosuly not inbound tones signalling. We have several menus,playing prompts,etc... and then we get here. Please be aware it tries to do the call but not through the proper isdn setup messages. It dials 627549229 Let us know why it didn´t dialing out with isdn signalling. Many thanks in advance. José Luis 175921.94 13 tw wav->vox convert end 241484,D:\Scripts\Servicio_Locutorios\Menu_Principal.vox,1,0,, 175921.95 13 play start ok, lPlayId=241546 175933.89 13 tw PlayEnd 13 241546 175933.91 13 play end id=241546, (is current id) 175933.92 13 event code=8001 scode=EV_PLAY_FINISHED state=1100 175933.94 13 state LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 175933.95 13 eng path {EV_PLAY_FINISHED} not found 175933.98 13 timer set 5 EV_TIMEOUT_REPLAYMSG 175934.00 13 tw DialogicEvent 129,TDX_PLAY,241546,0,0,,, 175934.02 13 event code=129 scode=TDX_PLAY state=1101 175934.03 13 state LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 175934.06 13 eng path {TDX_PLAY} not found 175934.53 13 tw dtmf 0 (13,48,48) 175934.55 13 event code=48 scode=0 state=1101 175934.56 13 state LsPlayMsgFinished 0,0 175934.58 13 rv add [Menu_Locutorio]{0} 175934.61 13 tw DialogicEvent 134,TDX_CST,48,0,0,DE_DIGITS,, 175934.63 13 event code=134 scode=TDX_CST state=6001 175934.64 13 timer clear 175934.83 13 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 175935.17 13 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 175935.20 13 event code=9012 scode=EV_TIMEOUT_READYTOBEGINTRANSFER state=1900 175935.22 13 state LsXferStart : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 175935.25 13 eng path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 175935.27 13 eng timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime) (30 sec) 175935.28 13 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 175935.30 13 state [Transfiere_Operador] Blind Dial and Connect to 627549229 (Generate) 175935.31 13 eng play first hookflash 175935.34 13 tw PlayEnd 13 0 175935.36 13 play end id=0, current id=241546 175935.38 13 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 175935.39 13 event code=132 scode=TDX_DIAL state=1931 175935.42 13 eng LsXferR4_PlayingHookflash1 132,TDX_DIAL,0,0,0,,, 175935.44 13 eng VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 175935.45 13 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 175936.50 13 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,TID_DIAL_LCL, 175936.52 13 event code=134 scode=DIALTONE state=1931 175936.53 13 eng LsXferR4_PlayingHookflash1 134,DIALTONE,193,0,0,DE_TONEON,TID_DIAL_LCL, 175936.55 13 event code=134 scode=TID_DIAL_LCL state=1931 175936.56 13 eng LsXferR4_PlayingHookflash1 134,TID_DIAL_LCL,193,0,0,DE_TONEON,TID_DIAL_LCL, 175936.59 13 event code=134 scode=TDX_CST state=1931 175936.61 13 eng LsXferR4_PlayingHookflash1 134,TDX_CST,193,0,0,DE_TONEON,TID_DIAL_LCL, 175937.61 13 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 175937.61 13 event code=9030 scode=EV_TIMEOUT_Transfer_Prefix_PauseAfter state=1931 175937.63 13 eng LsXferR4_PlayingHookflash1 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 175937.66 13 eng Dial(627549229) call 175937.67 13 eng Dial(627549229) ok 175942.13 13 tw DialogicEvent 133,TDX_CALLP,10,4,0,TDX_CALLP,CR_CNCT,CON_PAMD 175942.13 13 event code=133 scode=CON_PAMD state=1934 175942.16 13 eng LsXferR4_WaitForCallProgressInfo1 133,CON_PAMD,10,4,0,CR_CNCT,CON_PAMD,CON_PAMD 175942.17 13 event code=133 scode=TDX_CALLP state=1934 175942.19 13 eng LsXferR4_WaitForCallProgressInfo1 133,TDX_CALLP,10,4,0,CR_CNCT,CON_PAMD,CON_PAMD 175942.20 13 eng path {CON_PAMD} not found 175942.22 13 eng path {PAMD} not found 175942.25 13 eng path {am} not found 175942.27 13 state LsXferPlayVts EV_PLAY_FINISHED,EV_PLAY_FINISHED 175942.28 13 timer set 1 EV_TIMEOUT_HANGUP 175943.28 13 timer fired EV_TIMEOUT_HANGUP 175943.28 13 event code=9001 scode=EV_TIMEOUT_HANGUP state=1934 175943.30 13 eng LsXferR4_WaitForCallProgressInfo1 9001,EV_TIMEOUT_HANGUP,0,0,0,,, 175943.31 13 rv add [Hangup Time]{2/17/2005 5:59:43 PM} 175943.34 13 state Hanging up call... 175943.36 13 HangupCall_Common hCall=13 175943.38 13 rec RecSoundStop ok 175943.39 13 play PlaySoundStop ok 175943.41 13 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 175943.44 13 eng fnHangupCall end 175943.47 13 tw DialogicEvent 2137,GCEV_RELEASECALL,2137,0,0,,, 175943.63 13 event code=2137 scode=GCEV_RELEASECALL state=900 175943.66 13 state LsAwaitingCalls EV_UNKNOWN_2137 175943.67 13 event callstate IDLE 13 0 0 175943.69 13 eng WorkingMode@Idle= 175943.70 13 timer clear 175943.73 13 rec RecSoundStop ok 175943.75 13 play PlaySoundStop ok 175943.77 13 rv add [CallEndTime]{2/17/2005 5:59:43 PM} 175943.78 13 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 175944.78 13 timer fired EV_TIMEOUT_TIMETOREINITLINE 175944.78 13 event code=9008 scode=EV_TIMEOUT_TIMETOREINITLINE state=900 175944.80 13 state LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 175944.81 13 init atidle reinit : start 175944.84 13 init atidle reinit : reset all LineState variables 175944.86 13 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 175944.88 13 state Waiting for a call... 175945.22 13 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 175945.22 13 event code=9013 scode=EV_TIMEOUT_ATERIDLE_ALLOWOUT state=900 Share this post Link to post
SupportTeam Report post Posted 02/17/2005 10:14 PM Please be aware it tries to do the call but not through the proper isdn setup messages. Can you make outgoing calls on that E1 with Dialogic’s ISDIAG test tool? Does your email address end in "xtratelecom.es" ? Share this post Link to post
Guest Jose Luis Pérez Report post Posted 02/18/2005 12:24 AM how can i use isdiag? apparently is a debugger for dialogic or similar. correct? yes my email is jlperez@xtralecom.es do we need de vgdialer for this? to send calls out to a call center through de dialogic card. Share this post Link to post
SupportTeam Report post Posted 02/18/2005 01:08 AM ISDAIG is a tool from Dialogic - it should be installed on your system already in Dialogic's \bin\ directory. To make outgoing calls from the system you will need VG Dialer. On E1 ISDN lines the usual way to 'transfer' calls to a call center is to place a call on another channel and then connect the two calls together on the card itself (this is sometimes call 'call tromboning'). To do this with VG just use a Call Transfer module and select the "Dial and Conference" option, then specify the number to be dialed and optionally specify on which lines the call is to go out on... that's it. We have quite a few systems using this on E1 ISDN lines (and analog as well). A common architecture it to have E1 from the telco plugged into he Dialogic card then a 4 port analog card in the same box attached to call center’s analog extensions, with any incoming E1 calls that need to be connected through to the call centre then "Dial and Conferenced" out over the analog lines... Share this post Link to post
