Guest Steve Report post Posted 02/20/2005 12:27 PM I am using auto dialer to make survey, I getting a problem, which variable can result a Dial ID ? so I can insert to the database what ID was dialed. Thank you~! Share this post Link to post
SupportTeam Report post Posted 02/20/2005 08:44 PM If you want to assign some unique ID to the outbound call then at the time of loading the call just specify your own Result Variable and assign to it your own unique ID number. You will then be able to use this RV inside the scripts that run when that outbound call is made. Share this post Link to post
